NRF Connect - Can't Open VS Code from Toolchain
Hi - Recently, the NRF Connect Toolchain manager stopped being able to open VS Code and hangs spinning - screenshot below. It used to work so I'm not sure what's changed...
I am on a Mac M1 MacOS Monterey 12.0.1.
Toolchain manager v.0.10.3
nRF Connect for Desktop v3.10.0; SDK v.1.8.0
I include the output from VS Code  - Generate Support Info below (I ran VS code separately after Toolchain manager failed to open it).
Is there a way to manually set all the proper VS Code extension variable settings so I can develop from within VS Code without relying on the Toolchain manager to launch VS Code, or is there something obvious I'm not doing properly?
I saw someone else report that they encountered a similar error but they mistakenly already had VS Code running - that is not my issue. I made sure VS Code was not already running.
Thanks - appreciate any help or guidance! Dan.
Note: per the installation instructions, I installed the x64 version of VS Code: Version: 1.64.1
Commit: d6ee99e4c045a6716e5c653d7da8e9ae6f5a8b03
Date: 2022-02-07T17:26:08.977Z
Electron: 13.5.2
Chromium: 91.0.4472.164
Node.js: 14.16.0
V8: 9.1.269.39-electron.0
OS: Darwin x64 21.1.0
[19:59:59] west build --build-dir /Users/me/dev/nordic/blinky/build /Users/me/dev/nordic/blinky --pristine --board nrf5340dk_nrf5340_cpuapp -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/me/dev/nordic/mylock" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DCONF_FILE:STRING="/Users/me/dev/nordic/blinky/prj.conf"
[19:59:59] Failure (code 2).
[20:00:09] west build --build-dir /Users/me/dev/nordic/blinky/build /Users/me/dev/nordic/blinky --pristine --board nrf5340dk_nrf5340_cpuapp -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/me/dev/nordic/mylock" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DCONF_FILE:STRING="/Users/me/dev/nordic/blinky/prj.conf"
[20:00:09] Failure (code 2).
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "darwin",
    "osVersion": "Darwin Kernel Version 21.1.0: Wed Oct 13 17:33:01 PDT 2021; root:xnu-8019.41.5~1/RELEASE_ARM64_T6000",
    "osKernel": "21.1.0",
    "vscode": "1.64.1",
    "electron": "13.5.2",
    "node": "v14.16.0"
  "system": {
    "date": "2022-02-09T04:02:34.189Z",
    "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
    "vscodeUptime": "00:03:04",
    "osUptime": "00:13:04",
    "cpu": {
      "model": "Apple M1 Max",
      "speed": "24 MHz",
      "count": 5
    "memory": {
      "total": "32.00 GB",
      "free": "3.65 GB"
  "workspace": {
    "name": "mylock (Workspace)",
    "workspaceFile": "/Users/me/dev/nordic/mylock/src/mylock.code-workspace",
    "folders": [
      "/Users/me/dev/nordic/mylock",
      "/Users/me/dev/nordic/blinky"
  "extensions": {
    "internal": {
        "version": "2022.1.192",
        "path": "/Users/me/.vscode/extensions/nordic-semiconductor.nrf-connect-2022.1.192",
        "isActive": true
        "version": "2022.1.30",
        "path": "/Users/me/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.1.30",
        "isActive": true
      "nordic-semiconductor.devicetree": null,
      "nordic-semiconductor.kconfig": null
    "external": {
      "marus25.cortex-debug": "1.2.2",
      "ms-vscode.cpptools": "1.8.5",
      "ms-vscode.js-debug": "1.64.2",
      "ms-vscode.js-debug-companion": "1.0.15",
      "ms-vscode.references-view": "0.0.81",
      "ms-vscode.vscode-js-profile-table": "0.0.18",
      "cschlosser.doxdocgen": "1.3.2",
      "jeff-hykin.better-cpp-syntax": "1.15.11",
      "ms-azuretools.vscode-docker": "1.19.0",
      "ms-vscode-remote.remote-containers": "0.217.1",
      "ms-vscode-remote.remote-ssh": "0.70.0",
      "ms-vscode-remote.remote-wsl": "0.64.2",
      "ms-vscode.cmake-tools": "1.9.2",
      "ms-vscode.cpptools-extension-pack": "1.1.0",
      "ms-vscode.cpptools-themes": "1.0.0",
      "twxs.cmake": "0.0.17"
  "tools": {
    "/Applications/SEGGER/JLink/JLinkExe": "7.58b",
    "/usr/local/bin/nrfjprog": "10.15.1",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/cmake": "3.21.1",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/west": "0.12.0",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/python3": "3.9.6",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/ninja": "1.10.2",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/gperf": "3.1",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/dtc": "1.6.1",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/arm-none-eabi-gcc": "9-2019-q4-major",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/gn": "1961",
    "/opt/nordic/ncs/v1.8.0/toolchain/bin/git": "2.32.0"
  "connectedDevices": [
      "id": "1050007787"
  "config": {
      "topdir": "${nrf-connect.sdk:1.8.0}",
      "toolchain": {
        "path": "${nrf-connect.toolchain:1.8.0}"
      "ozonePath": "",
      "applications": [
      "jlink": {
        "rtosPlugin": ""
      "kconfig": {
        "interface": "guiconfig"
      "welcome": {
        "showOnStartup": false
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": false
      "terminalMode": "character"
    "nordic-semiconductor.devicetree": {
      "modules": [
        "${zephyrBase}",
        "${zephyrBase}/../nrf",
      "zephyr": "",
      "ctxFile": "",
      "defaultBoard": ""
    "nordic-semiconductor.kconfig": {
      "root": "",
      "env": {},
      "cfiles": true,
      "disable": false,
      "zephyr": {
        "base": ""
      "python": "",
      "liveValue": true
    "marus25.cortex-debug": {
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "enableTelemetry": true,
      "flattenAnonymous": false,
      "registerUseNaturalFormat": true,
      "variableUseNaturalFormat": true,
      "dbgServerLogfile": null,
      "showDevDebugOutput": "none"
  "environment": {
    "westExe": "/opt/nordic/ncs/v1.8.0/toolchain/bin/west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "GIT_EXEC_PATH": "/opt/nordic/ncs/v1.8.0/toolchain/Cellar/git/2.32.0_1/libexec/git-core",
      "HOME": "/Users/me",
      "PATH": "/opt/nordic/ncs/v1.8.0/toolchain/bin:/opt/homebrew/bin:/opt/homebrew/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin",
      "ZEPHYR_BASE": "/opt/nordic/ncs/v1.8.0/zephyr",
      "GNUARMEMB_TOOLCHAIN_PATH": "/opt/nordic/ncs/v1.8.0/toolchain",
      "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
      "USER": "me"
    "toolchainPath": "/opt/nordic/ncs/v1.8.0/toolchain",
    "toolchainBinPath": "/opt/nordic/ncs/v1.8.0/toolchain/bin",
    "toolchainVersion": "1.8.0"
  "terminal": {
    "shell": null,
    "defaultProfile": null
  • Hi Dan,
    Our team has tried this and they are able to access from Toolchain. It looks like in your log file, it says west is not found. It could be due to not proper installation. I understand that you have tried this, but could you try uninstalling and removing the entire toolchain directory for v1.8.0 and then install it once again? Also, could you share your path where you stored the v1.8.0 file?
    Priyanka
  • I would just like to add that I am having the exact same problem on an M1 Mac, but I found out that if I install a "wrong" non-intel version of VS code, toolchain manager will successfully launch VS code. Additionally if I don't let Toolchain manager run VSCode, I also get build errors. I have a related ticket here: https://devzone.nordicsemi.com/f/nordic-q-a/84157/sudden-build-errors-in-visual-studio-code
    I just wanted to add a data point to this problem and say it isn't unique to exclusively Dan's system!
  • Hi Priyanka - since I did a clean reinstall, the toolchain manager log does report that west is found, but it still loops endlessly searching for dependencies and refuses to launch VS Code. I attach my most recent log file output in case it is helpful.
    You asked about the path to the v1.8.0 install. Here it is: /opt/nordic/ncs/v1.8.0
    It contains the following subdirectories:
    bootloader modules nrfxlib toolchain zephyr
    mbedtls nrf test tools
    2022-02-12T00:54:12.740Z INFO Initializing environments...
    2022-02-12T00:54:12.745Z INFO Locally exsisting environment found at /opt/nordic/ncs/v1.8.0/toolchain
    2022-02-12T00:54:12.745Z INFO With version: v1.8.0
    2022-02-12T00:54:12.745Z INFO With west found: yes
    2022-02-12T00:54:12.853Z INFO Application data folder: /Users/me/Library/Application Support/nrfconnect/pc-nrfconnect-toolchain-manager
    2022-02-12T00:54:14.384Z DEBUG iface: en0
    2022-02-12T00:54:14.384Z DEBUG IP4: 10.0.0.32
    2022-02-12T00:54:14.384Z DEBUG IP6: fe80::47e:b741:8448:a9ca
    2022-02-12T00:54:14.384Z DEBUG MAC: f4:d4:88:6c:05:22
    2022-02-12T00:54:14.386Z DEBUG Client Id: 76597f53cc45b3d40b10a4ad54a5f34316332e6e
    2022-02-12T00:54:14.395Z DEBUG Google Analytics for category pc-nrfconnect-toolchain-manager has initialized
    2022-02-12T00:54:14.730Z DEBUG App pc-nrfconnect-toolchain-manager v0.10.3 official
    2022-02-12T00:54:14.730Z DEBUG App path: /Users/me/.nrfconnect-apps/node_modules/pc-nrfconnect-toolchain-manager
    2022-02-12T00:54:14.730Z DEBUG nRFConnect 3.10.0, required by the app is (^3.7.0)
    2022-02-12T00:54:14.730Z DEBUG nRFConnect path: /Applications/nRF Connect for Desktop.app/Contents/Resources/app.asar
    2022-02-12T00:54:14.730Z DEBUG HomeDir: /Users/me
    2022-02-12T00:54:14.730Z DEBUG TmpDir: /var/folders/lh/86j7kz7x3kl3xqd_zsw8vhzh0000gn/T/
    2022-02-12T00:54:14.786Z DEBUG Downloading index json with buffer length: 3848
    2022-02-12T00:54:14.787Z DEBUG Downloading index json with buffer length: 2761
    2022-02-12T00:54:14.788Z DEBUG Index json has been downloaded with result: [
            "version": "v1.4.99-dev1",
            "toolchains": [
                    "version": "20201207",
                    "name": "ncs-toolchain-v1.4.99-dev1-20201207-43d4695.dmg",
                    "sha512": "9eab039a75e8b2003e896b1a5832b642524fd225eb8b4d03fda4593e610785401e7600ac3f63533ea2bfee51bdd52eece0bb52073f79d20978ad3a01e5803d18"
            "version": "v1.4.1",
            "toolchains": [
                    "version": "20201215",
                    "name": "ncs-toolchain-v1.4.1-20201215-7ecf886.dmg",
                    "sha512": "9f8b07e1074177a3f821dc5b5eeccdf3af6cf7e38531db809ee5e185aeab12e5e7e92bf9ae7096ff2ec5be3d112bfacac90dea17ed02354c416d4404a1981d56"
            "version": "v1.4.0",
            "toolchains": [
                    "version": "20201030",
                    "name": "ncs-toolchain-v1.4.0-20201030-2750604.dmg",
                    "sha512": "b856df471eb8c05eef6bcadb1df0c8569d68b5da1f2e9f6bd5a7aaf80e35d4d02f615bba7bc10767abb88274d6d65e0e5565ea775831c0228170102d03c943fb"
            "version": "v1.3.2",
            "toolchains": [
                    "version": "20201012",
                    "name": "ncs-toolchain-v1.3.2-20201012-09b2ade.dmg",
                    "sha512": "2ba77cb1ab4e3f43c44214d653e78efb2b567d95faead5804aebaafeb7bba4691adc432d57f368aad2b8105b489e21cd640a9bd8af98a8697ed53d653f3b9dc1"
            "version": "v1.3.1",
            "toolchains": [
                    "version": "20200921",
                    "name": "ncs-toolchain-v1.3.1-20200921-509f057.dmg",
                    "sha512": "d02566fcd719b44db2985068e0d190d93876d8d867d53a8e0119de0a6060522a608305f2cf1bc61e3c89c7eb999e4cdfbad5654424e7cda746ff7cbf21438bb6"
            "version": "v1.3.0",
            "toolchains": [
                    "version": "20200618",
                    "name": "ncs-toolchain-v1.3.0-20200618-509f057.dmg",
                    "sha512": "a17558612678b33afd1b710a96e1ff68c56b7a75e52d63cd48f8781f8b9a8bca700e05e9a855d305d501a080ee930ebbda225df7f1b5575b1a0a8c5bef5f3621"
            "version": "v1.3.0-rc1",
            "toolchains": [
                    "version": "20200602",
                    "name": "ncs-toolchain-v1.3.0-rc1-20200602-dbcfd6c.dmg",
                    "sha512": "6d43ac2808ba3ba6a17e3f1c31eeb679886aa8a16fca6f3ad4b82077c66c3210e3c46581fc852da5fce07d098f170cc780cc05a41148ddf6a7032a0ff315307d"
                    "version": "20200609",
                    "name": "ncs-toolchain-v1.3.0-rc1-20200609-590da70.dmg",
                    "sha512": "2c58b3b2b4773da95ca95a2cea5e03ed48144b0d2dc0e03e00b06d8f65c56e5091d6b6410d78251ef5aa3bd03c8718cf5a04b5e8c7f3f08eadf1b518129dc708"
            "version": "v1.4.2",
            "toolchains": [
                    "version": "20210113",
                    "name": "ncs-toolchain-v1.4.2-20210113-7ecf886.dmg",
                    "sha512": "e4b9f8cac9e77305be89e3ea8b90dbcc22415e87379ff34c7c0cb0100c5109498167e22829e8bad5c01a84a84309467f970d7b4b8ecc46bf8b6724ef6f70e8cb"
            "version": "v1.5.0-rc1",
            "toolchains": [
                    "version": "20210215",
                    "name": "ncs-toolchain-v1.5.0-rc1-20210215-2c30941.dmg",
                    "sha512": "4c8c127c27ca67ac555f6d02c4bee3c50fc53d32fc6989a7158c2c95be87c2fb5b86b0953a8eb99342c6145b3fbfea035cda2e7e13d0b921868c63c7f1f4388f"
            "version": "v1.5.0",
            "toolchains": [
                    "version": "20210225",
                    "name": "ncs-toolchain-v1.5.0-20210225-607a0e0.dmg",
                    "sha512": "40d395b683c1b7680db30ba167a7d7742d2b756d7f7f8c2b4780091339f8141779b6e2d5f236b6e4ff13eba0ccf67a3240108ec76180950fbe2346a60220d404"
            "version": "v1.5.1-rc1",
            "toolchains": [
                    "version": "20210409",
                    "name": "ncs-toolchain-v1.5.1-rc1-20210409-96ab6aa.dmg",
                    "sha512": "c4b22656ce6e08b6881cd07fe446e75bb4400582f6dcf9d93e53feb116a1e3819a5d08dc0e87abaaf230054c8a396d5972b3573ad653f9bc5cdf479df336e5bc"
            "version": "v1.5.1",
            "toolchains": [
                    "version": "20210416",
                    "name": "ncs-toolchain-v1.5.1-20210416-96ab6aa.dmg",
                    "sha512": "b853cb30f76601ea9edefa2faade433280517b2262b1126efacf030c9c5582629b25974dfde4038327a5ffccc5a17a801597aee6e43f43767038abd3b8a89714"
            "version": "v1.6.0",
            "toolchains": [
                    "version": "20210701",
                    "name": "ncs-toolchain-v1.6.0-20210701-de414c8.dmg",
                    "sha512": "8aab26ffb89ff250882e272b262ddacc38fc1dc4cbec39f4e76468a0bfd899bc571caa1cb60b467e396422765fd207e8b48aaf48b25b0741ea375b39bd52d691"
            "version": "v1.6.1",
            "toolchains": [
                    "version": "20210907",
                    "name": "ncs-toolchain-v1.6.1-20210907-80db958.dmg",
                    "sha512": "b2e5c2da037e8ce577a799427b4a4bcc4a5d2608126bd152da4c52664e16cd2443528c040426163b7938f65c0c62dc80038ae76d74f72cb7b2e66fe9f254f6db"
            "version": "v1.7.0",
            "toolchains": [
                    "version": "20210923",
                    "name": "ncs-toolchain-v1.7.0-20210923-4c380d0.dmg",
                    "sha512": "6691fee7190f940e6adfa8fd2881ca14bae2a299671a58e21b8a1727944bf31542f62b97adb8c81c32d1baed03badfb96247de5d71f24052f00fc0f62124d5ec"
            "version": "v1.7.1",
            "toolchains": [
                    "version": "20211028",
                    "name": "ncs-toolchain-v1.7.1-20211028-4c380d0.dmg",
                    "sha512": "6d567b869613d8722cf542e3d7bea883987958e70dd2e6ba69ac846ad68ff002c676c9b1647bd7dc1197af3ac6c75d56945a8de8f93655dc1656d19391df992a"
            "version": "v1.8.0",
            "toolchains": [
                    "version": "20220103",
                    "name": "ncs-toolchain-v1.8.0-20220103-7d41729.dmg",
                    "sha512": "fb931ed3773c6745c1eeca4963d30aebe2f1a1b41a4340121fc7999ccb0340a76d671defa50b5bdae1b4317d9e49bd7a08583cc6d210fe30c16b0e0bbcfc736b"
    2022-02-12T00:54:14.791Z INFO Toolchain v1.4.99-dev1 has been added to the list
    2022-02-12T00:54:14.798Z INFO Toolchain v1.4.1 has been added to the list
    2022-02-12T00:54:14.803Z INFO Toolchain v1.4.0 has been added to the list
    2022-02-12T00:54:14.830Z INFO Toolchain v1.3.2 has been added to the list
    2022-02-12T00:54:14.840Z INFO Toolchain v1.3.1 has been added to the list
    2022-02-12T00:54:14.849Z INFO Toolchain v1.3.0 has been added to the list
    2022-02-12T00:54:14.902Z INFO Toolchain v1.3.0-rc1 has been added to the list
    2022-02-12T00:54:14.951Z INFO Toolchain v1.4.2 has been added to the list
    2022-02-12T00:54:14.969Z INFO Toolchain v1.5.0-rc1 has been added to the list
    2022-02-12T00:54:15.005Z INFO Toolchain v1.5.0 has been added to the list
    2022-02-12T00:54:15.031Z INFO Toolchain v1.5.1-rc1 has been added to the list
    2022-02-12T00:54:15.053Z INFO Toolchain v1.5.1 has been added to the list
    2022-02-12T00:54:15.066Z INFO Toolchain v1.6.0 has been added to the list
    2022-02-12T00:54:15.070Z INFO Toolchain v1.6.1 has been added to the list
    2022-02-12T00:54:15.074Z INFO Toolchain v1.7.0 has been added to the list
    2022-02-12T00:54:15.085Z INFO Toolchain v1.7.1 has been added to the list
    2022-02-12T00:54:15.092Z INFO Toolchain v1.8.0 has been added to the list
  • Hi Dan,
    I have passed on the information to the experts and will get back to you soon.
    Priyanka
  • I also am having this issue on an M1 Mac, just as Dan and Griffin described.
    In addition, Griffin and I are having build issues that might be resolved if we can launch VS Code via Toolchain Manager, assuming it sets up environment variables necessary to build a project with MCUBOOT.
    Steve
