SPI Master - Slave sample under zephyr
I can not get the SPI Slave function working on nRF52840 (nrf52840dk_nrf52840 board). My goal is to have spi0 as master and spi1 as slave.
By linking the MISO en MOSI lines, CS and clock lines, I want to send data from spi0 to spi1.
In the nrf52840dk_nrf52840.overlay I wrote:
&spi1 {
  compatible = "nordic,nrf-spis";
  label = "SPI_1";
  status = "okay";
  sck-pin = <31>;
  mosi-pin = <30>;
  miso-pin = <40>;
  csn-pin = <10>;
  def-char = <0xFF>;
&spi0 {
  label = "SPI_0";
  status = "okay";
  sck-pin = <27>; //p0.27
  mosi-pin = <26>; //p0.26
  miso-pin = <29>; //p0.29
In the pr.conf I wrote:
# adding SPI communication
CONFIG_SPI=y
CONFIG_SPI_SLAVE=y
In the main loop I wrote:
struct device * spi1;
struct device * spi0;
struct spi_config spi1_cfg;
struct spi_config spi0_cfg;
/* master buffers */
uint8_t spi0_rx_buffer[SPI_BUFFER_SIZE];
uint8_t spi0_tx_buffer[] = "Hello World";
struct spi_buf bufsm_r =
  .buf = &spi0_rx_buffer,
  .len = SPI_BUFFER_SIZE
struct spi_buf_set rxm =
  .buffers = &bufsm_r,
  .count = 1
struct spi_buf bufsm_t =
  .buf = &spi0_tx_buffer,
struct spi_buf_set txm =
  .buffers = &bufsm_t,
  .count = 1
/* slaver buffers */
uint8_t spi1_rx_buffer[SPI_BUFFER_SIZE];
uint8_t spi1_tx_buffer[SPI_BUFFER_SIZE];
struct spi_buf bufss_r =
  .buf = &spi1_rx_buffer,
struct spi_buf_set rxs =
  .buffers = &bufss_r,
  .count = 1
struct spi_buf bufss_t =
  .buf = &spi1_tx_buffer,
struct spi_buf_set txs =
  .buffers = &bufss_t,
  .count = 1
#define CSN_PIN 11
int init_spi(void)
  csdev = device_get_binding("GPIO_0");
  if (!csdev) {
    printk("Could not find GPIO_0 driver\n");
    return -1;
  gpio_pin_configure(csdev, CSN_PIN, GPIO_OUTPUT);
  gpio_pin_set(csdev, CSN_PIN, 1);
/* slave settings */
  spi1 = device_get_binding("SPI_1");
  if (!spi1) {
    printk("Could not find SPI 1 driver\n");
   return -1;
  spi1_cfg.operation = SPI_WORD_SET(8) | SPI_OP_MODE_SLAVE;
  spi1_cfg.frequency = 1000000;
/* master settings */
  spi0 = device_get_binding("SPI_0");
  if (!spi0) {
    printk("Could not find SPI 0 driver\n");
    return -1;
  spi0_cfg.operation = SPI_WORD_SET(8) | SPI_OP_MODE_MASTER;
  spi0_cfg.frequency = 1000000;
  rxm.count = 1;
  rxs.count = 1;
return 0;
void spi_slave_task(void)
  for( ; ; )
   int rets = spi_transceive(spi1,&spi1_cfg,&txs,&rxs);
   LOG_INF("spi_transceive, slave mode reported %d",rets);
   if(rets > 0)
     printk("Received: 0x%02X 0x%02X 0x%02X-- \n", spi1_rx_buffer[0],spi1_rx_buffer[1],spi1_rx_buffer[2]);
 k_msleep(10);
in the main loop, I just called
  gpio_pin_set(csdev, CSN_PIN, 0);
  int retm = spi_transceive(spi0,&spi0_cfg,&txm,&rxm);
  LOG_INF("spi_transceive, master mode reported %d",retm);
  k_msleep(1000);
But in the slave task, I expected some data, however no data was received. Only  "Timeout waiting for transfer to complete"
Is there any hint how to get forward?
