I use peripheral_hr sample code of V1.7.1 version to send Data HRM by Bluetooth. the frequency is 22 Hz only.
I would like to icrease sample rate to 2 KHz, could i do it with this sample code? How??
or there is other sample code for ?
Here attached source code
Thank you
/* main.c - Application main entry point */
* Copyright (c) 2015-2016 Intel Corporation
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/bas.h>a
#include <bluetooth/services/hrs.h>
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_UUID16_ALL,
BT_UUID_16_ENCODE(BT_UUID_HRS_VAL),
BT_UUID_16_ENCODE(BT_UUID_BAS_VAL),
BT_UUID_16_ENCODE(BT_UUID_DIS_VAL))
static void connected(struct bt_conn *conn, uint8_t err)
if (err) {
printk("Connection failed (err 0x%02x)\n", err);
} else {
printk("Connected\n");
printk("Disconnected (reason 0x%02x)\n", reason);
static struct bt_conn_cb conn_callbacks = {
.connected = connected,
.disconnected = disconnected,
static void bt_ready(void)
int err;
printk("Bluetooth initialized\n");
err = bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), NULL, 0);
if (err) {
printk("Advertising failed to start (err %d)\n", err);
return;
printk("Advertising successfully started\n");
static void auth_cancel(struct bt_conn *conn)
printk("Pairing cancelled: %s\n", addr);
static struct bt_conn_auth_cb auth_cb_display = {
.cancel = auth_cancel,
static void bas_notify(void)
uint8_t battery_level = bt_bas_get_battery_level();
battery_level--;
if (!battery_level) {
battery_level = 100U;
bt_bas_set_battery_level(battery_level);
static void hrs_notify(void)
static uint8_t heartrate = 90U;
/* Heartrate measurements simulation */
heartrate++;
if (heartrate == 160U) {
heartrate = 90U;
bt_hrs_notify(heartrate);
void main(void)
int err;
err = bt_enable(NULL);
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return;
bt_ready();
bt_conn_cb_register(&conn_callbacks);
bt_conn_auth_cb_register(&auth_cb_display);
/* Implement notification. At the moment there is no suitable way
* of starting delayed work so we do it here
while (1) {
k_sleep(K_SECONDS(1));
hrs_notify();
/* Battery level simulation */
bas_notify();
