We are developing an application in which we need to modify an existing device driver.
It's about LIS2DH driver that is part of nRF Connect SDK v1.8.0 and we are using VSCode.
Currently we have working app a proof of concept, and we need to remove some data processing as we need raw sensor samples, and we do not want to edit SDK, because we want our changes in our repo and also not the entire SDK code base.
The plan was as follows, transfer the existing driver folder from SDK to our codebase, remove any switches and defines that links SDK driver from prj.conf (CONFIG_SENSOR=y, CONFIG_LIS2DH=y), modify CMakeLists.txt, to include files in src subdirectory, modify Kconfig so we wont use SDKs driver.
And here begins an infinite number of build errors, dual Kconfig processing, missing defines,...
We tried many things many times... without results.
We will appreciate a point to right direction.
Thank you!
