Dear friend,
Since the customized nRF5340 board does not have an external 32.768KHz low-frequency crystal oscillator, the following is added to prj.conf in netboot:
# 32kHz clock source CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
The build will appear the following error:
[144/151] Linking C executable zephyr\zephyr_prebuilt.elf FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map cmd.exe /C "cd . && E:\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=E:/ncs/v1.8.0/nrf/samples/nrf5340/netboot/build_nrf5340dk_nrf5340_cpunet/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp" -LE:/ncs/v1.8.0/nrf/samples/nrf5340/netboot/build_nrf5340dk_nrf5340_cpunet/zephyr -lgcc zephyr/arch/common/libisr_tables.a E:/ncs/v1.8.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m33+nodsp/soft-float/liboberon_3.0.8.a -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cmd.exe /C "cd /D E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet\zephyr && E:\ncs\v1.8.0\toolchain\opt\bin\cmake.exe -E echo "" e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_sem_give': E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet/zephyr/include/generated/syscalls/kernel.h:953: undefined reference to `z_impl_k_sem_give' e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_sem_init': E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet/zephyr/include/generated/syscalls/kernel.h:918: undefined reference to `z_impl_k_sem_init' e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_mutex_init': E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet/zephyr/include/generated/syscalls/kernel.h:802: undefined reference to `z_impl_k_mutex_init' e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_mutex_lock': E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet/zephyr/include/generated/syscalls/kernel.h:820: undefined reference to `z_impl_k_mutex_lock' e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_sem_take': E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet/zephyr/include/generated/syscalls/kernel.h:936: undefined reference to `z_impl_k_sem_take' e:/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/sensor/nrf5/libdrivers__sensor__nrf5.a(temp_nrf5.c.obj): in function `k_mutex_unlock': E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet/zephyr/include/generated/syscalls/kernel.h:836: undefined reference to `z_impl_k_mutex_unlock' collect2.exe: error: ld returned 1 exit status ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'E:\ncs\v1.8.0\toolchain\opt\bin\cmake.EXE' --build 'E:\ncs\v1.8.0\nrf\samples\nrf5340\netboot\build_nrf5340dk_nrf5340_cpunet'
prj.conf does not add CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y and CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y to build successfully.
why? How to solve?
