I2S
HI
I am using the I2S on the nRF52840DK I have constructed an array and all works well except once I start it , it continues to run, I cant get it to play the sample just once, how can I do this
Start Code
NRF_I2S->ENABLE = 1;
// Configure data pointer
NRF_I2S->TXD.PTR = (uint32_t)&sine_table2[0];
NRF_I2S->RXTXD.MAXCNT = sizeof(sine_table2) / sizeof(uint32_t);
NRF_I2S->TASKS_START = 1;
for (;;)
    __WFE();
Any assistance would be appreciated.
Kind Regards
David
  • Hi Jared
    Thanks for getting back so promptly, I am trying to use your driver please see code below (first time I have used Nordic), I think I am mixing both, but it does work can you please amend so I am only using your driver and I am able to use the interrupt.
    #include <stdio.h>
    #include "nrf_drv_i2s.h"
    #include "nrf_delay.h"
    #include "app_error.h"
    #include "boards.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include <nrf.h>
    #include "sounds.h"
    #define PIN_MCK (41) //P1.09
    #define PIN_BCLK (40) //P1.08
    #define PIN_LRCK (38) //P1.06
    #define PIN_SDOUT (39) //P1.07
    #define Button 11
    #define LED 13
    static void data_handler(nrf_drv_i2s_buffers_t const * p_released,uint32_t status)
    uint32_t err_code = NRF_SUCCESS;
    err_code = NRF_LOG_INIT(NULL);
    nrf_drv_i2s_config_t config = NRF_DRV_I2S_DEFAULT_CONFIG;
    config.sck_pin = PIN_BCLK;
    config.lrck_pin = PIN_LRCK;
    config.sdout_pin = PIN_SDOUT;
    config.mode = I2S_CONFIG_MODE_MODE_Master;
    config.sample_width = I2S_CONFIG_SWIDTH_SWIDTH_16BIT;
    config.mck_setup = NRF_I2S_MCK_32MDIV8;
    config.ratio = NRF_I2S_RATIO_512X;
    config.channels = NRF_I2S_CHANNELS_RIGHT;
    err_code = nrf_drv_i2s_init(&config, data_handler);
    // // Enable transmission
    NRF_I2S->CONFIG.TXEN = (I2S_CONFIG_TXEN_TXEN_ENABLE << I2S_CONFIG_TXEN_TXEN_Pos);
    // // Configure data pointer
    nrf_gpio_cfg_output(LED);
    nrf_gpio_cfg_input(Button, NRF_GPIO_PIN_PULLUP);
    for (;;)
    if(nrf_gpio_pin_read(Button) == 0)
    nrf_gpio_pin_clear(LED);
    //printf("Button is Pressed \r\n");
    nrf_gpio_pin_set(LED);
    //printf("Button is Released \r\n");
    // Wait for an event.
    //__WFE();
    // Clear the event register.
    //__SEV();
    // __WFE();
    //NRF_LOG_FLUSH();
    Thank you
    David
    Have you seen our I2S example in the SDK? It shows how you can use the driver to stop a transfer after the a specific number of data has been transferred.
    regards
    Jared
  • Hi Jared
    Yes I have taken a look at the code but don't really understand it, I have attached my latest code and have  excluded from the build the nrfx_i2s the program compiles now without issue.
    The problem is when I run the program it seems to go immediately to the interrupt and doesn't play my file at all.
    I have confirmed this in debug mode it goes immediately to the Interrupt.
    can you please assist.
    #include <stdio.h>
    #include "boards.h"
    #include <nrf.h>
    #include "sounds.h"
    #define Button 11
    #define LED 13
    NRF_LOG_INFO("I2S loopback example started.");
    // Enable MCK generator
    NRF_I2S->CONFIG.MCKEN = (I2S_CONFIG_MCKEN_MCKEN_ENABLE << I2S_CONFIG_MCKEN_MCKEN_Pos);
    // MCKFREQ = 4 MHz
    NRF_I2S->CONFIG.MCKFREQ = I2S_CONFIG_MCKFREQ_MCKFREQ_32MDIV8 << I2S_CONFIG_MCKFREQ_MCKFREQ_Pos;
    // Ratio = 64
    NRF_I2S->CONFIG.RATIO = I2S_CONFIG_RATIO_RATIO_512X << I2S_CONFIG_RATIO_RATIO_Pos;
    // Master mode, 16Bit, left aligned
    NRF_I2S->CONFIG.MODE = I2S_CONFIG_MODE_MODE_MASTER << I2S_CONFIG_MODE_MODE_Pos;
    NRF_I2S->CONFIG.SWIDTH = I2S_CONFIG_SWIDTH_SWIDTH_16BIT << I2S_CONFIG_SWIDTH_SWIDTH_Pos;
    NRF_I2S->CONFIG.ALIGN = I2S_CONFIG_ALIGN_ALIGN_LEFT << I2S_CONFIG_ALIGN_ALIGN_Pos;
    // Format = I2S
    NRF_I2S->CONFIG.FORMAT = I2S_CONFIG_FORMAT_FORMAT_I2S << I2S_CONFIG_FORMAT_FORMAT_Pos;
    // Use stereo
    NRF_I2S->CONFIG.CHANNELS = I2S_CONFIG_CHANNELS_CHANNELS_RIGHT << I2S_CONFIG_CHANNELS_CHANNELS_Pos;
    // Configure pins
    NRF_I2S->PSEL.MCK = (PIN_MCK << I2S_PSEL_MCK_PIN_Pos);
    NRF_I2S->PSEL.SCK = (PIN_BCLK << I2S_PSEL_SCK_PIN_Pos);
    NRF_I2S->PSEL.LRCK = (PIN_LRCK << I2S_PSEL_LRCK_PIN_Pos);
    NRF_I2S->PSEL.SDOUT = (PIN_SDOUT << I2S_PSEL_SDOUT_PIN_Pos);
    //Enable interrupt and IRQ
    NRF_I2S->INTENSET = I2S_INTENSET_TXPTRUPD_Enabled << I2S_INTENSET_TXPTRUPD_Pos;
    NRF_I2S->EVENTS_TXPTRUPD = 0;
    //NVIC_EnableIRQ(I2S_IRQn);
    // Start transmitting I2S data
    //nrf_delay_ms(1200);
    for (;;)
    //if(nrf_gpio_pin_read(Button) == 0)
    // nrf_gpio_pin_clear(LED);
    // // Start transmitting I2S data
    // //NRF_I2S->ENABLE = 1;
    // //NRF_I2S->TASKS_START = 0;
    // //printf("Button is Pressed \r\n");
    //else
    // nrf_gpio_pin_set(LED);
    // //NRF_I2S->ENABLE = 0;
    // //NRF_I2S->TASKS_START = 1;
    // //printf("Button is Released \r\n");
    // // Wait for an event.
    // //__WFE();
    // // Clear the event register.
    // //__SEV();
    // // __WFE();
    ////NRF_LOG_FLUSH();
    void I2S_IRQHandler(void)
    if (NRF_I2S->EVENTS_TXPTRUPD == 1)
    NRF_I2S->TASKS_STOP = 1;
    nrf_delay_ms(100);
    Kind Regards
    David
    You're mixing the usage of the driver and writing directly to the peripheral. All calls that starts with NRF_I2S-> is omitting the driver and writing directly to the driver. I suggest that you clean up your code and remove all parts that write directly to the peripheral and only use the driver.
    regards
    Jared
  • Hi
    That is the problem, I don't know how to Write it using the driver.
    I found this code online and it worked but not for a single shot, you gave me the code with an interrupt handler as above but that doesn't work.
    The code you recommended (I2S example in the SDK),  does not use an interrupt handler I don't understand it.
    Regards
    David
