NUS ble_app_uart freezes when client app is closed while receiving data from peripheral
When the nRF52840 Dev Kit is sending data as a peripheral, connected to client running nRF Connect all works.
I am sending (streaming) a text file to iOS phone or Android tablet.
1)
If I close nRF Connect while streaming, the peripheral (nRF52840) stays connected.
I have to power cycle to get nRF52840 to start advertising again.
2)
If I send a 340-character text file to NUS, all is fine. I can disconnect and reconnect.
If I send a 360-character text file, NUS locks up (Freezes).s
Only a power cycle can get the Dev Kit to function.again.
Any help appreciated
I am using:
nRF52840
nRF5_SDK_17.1.0_ddde560
s140_nrf52_7.2.0_softdevice
When I use:
ble_app_uart
nRF5_SDK_15.3.0_59ac345
s132_nrf52_6.1.1_softdevice.hex
nRF52832 Dev Kit
I can send a file of320 bytes, no problem
When I send a file of 360 bytes, the nRF52832 Dev Kit (Peripheral) automatically disconnects, but does NOT freeze.
So the Client, (Android tablet), can reconnect.
    We are looking into your case and will reply later.
    Amanda
    Sorry for the delay.
    From the team:
    I modified the ble_app_uart example in the nRF5 SDK so that the firmware sends 360-byte text to the smartphone on button 4 press. However, I cannot reproduce the problem with my nRF52840 Dev Kit (PCA10056 v1.0.0) and nRF Connect Android application. The firmware does not freeze, it is able to send another 360-byte packet. On the Android side, it is also confirmed that the packets are received and the connection maintained.
    I am attaching a modified main.c file for the BLE UART example. It has a license tag instead of an actual license because I modified the files in our Bitbucket code repository instead of doing it with the release package. You may want to add a proper license.
    /*$$$LICENCE_NORDIC_STANDARD<2014>$$$*/
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_delay.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static volatile bool text_file_pending = false;
    static char text_file[] =
        'H', 'e', 'l', 'l', 'o',
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
            case BSP_EVENT_KEY_3:
                if (text_file_pending)
                    NRF_LOG_WARNING("Text file already in the pending mode");
                    text_file_pending = true;
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static void text_file_data_send(void)
        uint32_t err_code;
        bool keep_pending = false;
        static uint16_t text_file_index = 0;
            NRF_LOG_WARNING("No peer connected: cannot send the text file");
            uint16_t length;
            length = ARRAY_SIZE(text_file) - text_file_index;
            length = (length > BLE_NUS_MAX_DATA_LEN) ? BLE_NUS_MAX_DATA_LEN : length;
            err_code = ble_nus_data_send(&m_nus, text_file + text_file_index, &length, m_conn_handle);
            if (err_code == NRF_SUCCESS)
                text_file_index += length;
                NRF_LOG_INFO("Text file sending in progress... %d bytes sent out of %d",
                             text_file_index, ARRAY_SIZE(text_file));
                if (text_file_index < ARRAY_SIZE(text_file))
                    keep_pending = true;
                    NRF_LOG_INFO("Text file sending completed!");
            else if ((err_code == NRF_ERROR_BUSY) || (err_code == NRF_ERROR_BUSY))
                NRF_LOG_WARNING("Softdevice is busy");
                nrf_delay_ms(100);
                NRF_LOG_WARNING("Unable to send the text file: %04X", err_code);
        if (!keep_pending)
        text_file_pending = keep_pending;
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
                text_file_data_send();
    -Amanda
  • Amanda,
    Thanks for this, but there is still a problem.
    The magic number is around 400 characters.
    1)
    I placed the 'Hello" array into a Notepad text file. (720 lines of 'Hello')
    I use Tera Term to connect to the JLink CDC UART Port of the nRF52840 DevKit.
    I then use 'Send File' from Tera Term to send this 720 character file, and it freezes NUS every time.
    BLE disconnects with message:
    INFO Disconnected from device ED:FD:19:76:49:0E, reason: BLE_HCI_CONNECTION_TIMEOUT
    This is how the module is used in the real word, streaming text to the UART, simulating a wireless cable.
    2)
    I cut and paste the 360 array, to make it a 720 char array, of 'Hello'
    I press Button 4, and it works just great
    So there is a difference in sending text from within the UART app, as you did, or sending a text file through the external UART port.
    3)
    I can get the error to go away, if I comment out the //APP_ERROR_HANDLER(p_event->data.error_communication);
    In my case, when using a module with the nRF52840, the UART text is streamed to the external port,. So it crashes every time.
    If I send less then say 340 characters, and have some delay before sending another stream of characters, then nRF52840 will work.
    If I send say 400 or more chars, it crashes.
    The only way to get that to work, is to comment out the //APP_ERROR_HANDLER(p_event->data.error_communication);
    If this is acceptable to you, you should change the application logic to discard the communication errors with APP_UART by removing the following line:
    -Amanda
  • Amanda,
    As you can see from my earlier post, I am already commenting out the
    //APP_ERROR_HANDLER(p_event->data.error_communication); which is the same as removing the line.
    However,
    We are seeing continued UART problems, if data is streamed from the external UART RX pin to BLE client. Even with //APP_ERROR_HANDLER(p_event->data.error_communication); commented out, the NUS would freeze. The only way to get it to work, is to power cycle.
    This problem is seen if I stream text to the UART from an external UART, NOT internally generated data from the NUS app).
    I use nRFConnect, and see the data.
    Then while it is streaming, close nRFConnect.
    NUS will freeze, but not disconnect.
    I can talk to support directly, if you can send me a link.
