Hi
We are using NRF_51422 dongle in our university for Labs development with students
We were able to setup & install the NRF_sniffer. It is working with the command line python nrf_sniffer.py and we were able to capture traces with the command
python nrf_sniffer_ble.py --extcap-interface COM6-None --capture --fifo myOutput_connect.pcap
Unfortunately, we cannot for the moment capture CONNECT req messages.
In your doc you mention that (https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_sniffer_ble%2FUG%2Fsniffer_ble%2Fsniffer_usage.html) the 2nd mode of opertation allows
- Follow one particular device and try to catch all packets sent to or from this particular device. This mode catches all:
- Advertisements and Scan Responses sent from the device
- Scan Requests and Connect Requests sent to the device
- Packets in the connection sent between the two devices in the connection
But I cannot find any example of command line that allows this capture
In your doc here https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_sniffer_ble%2FUG%2Fsniffer_ble%2Fsniffer_usage.html you refer to wireshark for selecting the peripheral but in our case (cmd.exe not allowed on the PC) the automatic capture from wireshark is not possible. We have to capture manually & then open file from wireshark
We tried the following command
python nrf_sniffer_ble.py --extcap-interface COM6-None --capture --fifo myOutput_connect.pcap --device fd:e0:99:56:27:c2
But not CON_REQ message ..
Which procedure should we follow ?
Thanks a lot for your help
Regards
