How can I close a open BLE connection properly from peripheral side
in our final device, I want to give the user the opportunity, to close an opened BLE connection between our device and another smart device. This should be done by pushing a button. At the moment, if the button is pressed, I call the "closeBLEconnection" function.
uint32_t stopAdvertising(void){
uint32_t err_code;
err_code = sd_ble_gap_adv_stop();
	if(err_code != NRF_SUCCESS)
  ble_dbg_printf("stop dvertising error code: %x\r", err_code);
	return err_code;}
uint32_t closeBLEconnection(void){
	uint32_t err_code;
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION);
  ble_dbg_printf("Connection close error code: %d\r", err_code);
	err_code = stopAdvertising();
	return err_code;}
But if I use the functions like this, I will get NRF_ERRORS from both functions. Connection close returns with error code "7" and stop advertising function returns error code 8. How can I change the disconnection sequenze to get a proper result? It seems, that "BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION" is not a valid parameter for sd_ble_gap_disconnect!?
Regards, BTprogrammer
PS: I use the S120 softdevice as an peripheral.
  • As Alex mentioned you should use BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION, please see this question for the difference between BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION and BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION.
    Error code 0x00000007 from sd_ble_gap_adv_stop(); is NRF_ERROR_INVALID_STATE, which you can see above the function in ble_gap.h. And as Alex mentioned you probably get this because you are not actually advertising.
  • Hello, As you mentioned BLE_HCL_REMOTE_USER_TERMINATED_CONNECTION stopped the connection between central and peripheral. But advertising packets are still broadcasted even though I called sd_ble_gap_adv_stop() after stopping the connection. I checked this situation with a packet sniffer. Let me know how to stop advertising. I am using S110. Thanks. Now I mistook understanding my code: ble_evt_dispatch() calls ble_advertising_on_ble_evt(). Therefore, after stopping advertising, advertising restarts automatically. Sorry my dump message. Thanks.
