Problem Run and Test DTM at customer hardware with nRF52840
I face at least 2 problems and need some support.
What I want to achieve is that the DTM runs at our customer hardware for radio and later on BLE certification. 3 years ago we made this with nRF52832 and it was absolutely no problem, that's why I can't really understand the problems I face now.
I have a PCA10056, a nRF52840 Dongle (PCA10059) and my customer hardware with a Taiyo Yuden module using nRF52840. The SW for the nRF52840 is built in Eclipse using gcc; for debugging I use a Segger JTracePro.
As 3 years ago I first tried to use the nRF Connect at my PC with the stick, the old nRF51 stick was compatible and worked well with nRF Connect. In the forum I read that with the nRF52840 Dongle this will not work, so I use the PC10056. I have erased this board and flashed the file direct_test_mode_pca10056.hex from SDK17.1\examples\dtm\direct_test_mode\hex. When powering this board I see a LED flickering; when selecting this board at nRF Connect (in Windows) the flickering changes a little bit; when I click at Start test the LED's behaivour changes a little bit. It seems that this works, but can I make a test with the nRF52840 Dongle for verifying?
Now coming to the main problem: I use a customer elecronics where our standard Software with BLE traffic (using SDK13; soon we will change to Zephyr) runs perfect. So I can assume that the HW is ok. Parallel to our standard project I have created a DTM project; here I use SDK17.1 to be sure that we meet the latest requirements for the radio certification. I have created a custom_board.h file which just contains:
#define LEDS_NUMBER 0
#define BUTTONS_NUMBER 0
#define RX_PIN_NUMBER 12
#define TX_PIN_NUMBER 17
#define CTS_PIN_NUMBER UART_PIN_DISCONNECTED // 8
#define RTS_PIN_NUMBER UART_PIN_DISCONNECTED // 30
#define HWFC false
RX is connected to P0.12 and Tx to P0.17.
I can build the project; when setting a breakpoint to the first line current_time = dtm_wait();in the endless-loop for (;;) the system behaves as expected. Pressing then several times F6 (Step over) will result in toggling between the mentioned current_time = dtm_wait() line and the next if(app_uart_get(&rx_byte) != NRF_SUCCESS) instruction; this seems still fine for me. When I press then 'Run' I see the supply current heavily increasing to about 4 times of the current before; when I start a test in nRF Connect I see just the same as if the customer board is switched off. When pressing 'Suspend' the program flow stops at the if(nrf_timer_event_check(..) function in dtm_wait().
A breakpoint set to the last line SystemCoreClockUpdate(); in void SystemInit(void) in system_nrf52.c is never reached...
What is here wrong?
Thanks in advance for your help
MatthK
Here is my main() function, copied from the SDK17.1:
uint32_t dtm_error_code;
uint32_t current_time;
uint32_t msb_time = 0; // Time when MSB of the DTM command was read. Used to catch stray bytes from "misbehaving" testers.
bool is_msb_read = false; // True when MSB of the DTM command has been read and the application is waiting for LSB.
uint16_t dtm_cmd_from_uart = 0; // Packed command containing command_code:freqency:length:payload in 2:6:6:2 bits.
uint8_t rx_byte; // Last byte read from UART.
dtm_event_t result; // Result of a DTM operation.
uart_init();
dtm_error_code = dtm_init();
#if defined(NRF21540_DRIVER_ENABLE) && (NRF21540_DRIVER_ENABLE == 1)
//Initialization of nRF21540 front-end BluetoothRegistered range extender chip. Do not use if your hardware doesn't support it.
APP_ERROR_CHECK(nrf21540_init());
if (dtm_error_code != DTM_SUCCESS)
// If DTM cannot be correctly initialized, then we just return.
return -1;
for (;;)
// Will return every UART pool timeout,
if (app_uart_get(&rx_byte) != NRF_SUCCESS)
// Nothing read from the UART.
continue;
if (!is_msb_read)
// This is first byte of two-byte command.
is_msb_read = true;
dtm_cmd_from_uart = ((dtm_cmd_t)rx_byte) << 8;
msb_time = current_time;
// Go back and wait for 2nd byte of command word.
continue;
// This is the second byte read; combine it with the first and process command
if (current_time > (msb_time + MAX_ITERATIONS_NEEDED_FOR_NEXT_BYTE))
// More than ~5mS after msb: Drop old byte, take the new byte as MSB.
// The variable is_msb_read will remains true.
// Go back and wait for 2nd byte of the command word.
continue;
// 2-byte UART command received.
dtm_cmd_from_uart |= (dtm_cmd_t)rx_byte;
if (dtm_cmd(dtm_cmd_from_uart) != DTM_SUCCESS)
// Extended error handling may be put here.
// Default behavior is to return the event on the UART (see below);
// the event report will reflect any lack of success.
// Retrieve result of the operation. This implementation will busy-loop
// for the duration of the byte transmissions on the UART.
if (dtm_event_get(&result))
// Report command status on the UART.
// Transmit MSB of the result.
while (app_uart_put((result >> 8) & 0xFF));
// Transmit LSB of the result.
while (app_uart_put(result & 0xFF));
  • Hi Håkon,
    I have started a sweep at the nRF Connect for Windows with connected PCA10056 board; I can see the running channel at 0dBM at the (Transmitter) screen as expected. So I suppose that at the tester side everything runs as expected. Unfortunately nothing to see at the Receiver screen...
    Then I have measured at TXD at the FT230X, but I can see only 3.3V (probably idle mode) appear. Could this voltage creates problems as the nRF52840 is supplied with 3.0V? 3 years ago with nRF52832 and the same conditions every worked well.
    When I try to connect my custom hardware containing nRF52840 and the USB/UART bridge (FT230X) to the nRF Connect Software at the PC I click at 'Select Device'; then I get 'Unknown 0000... FFFF'. When selecting this device the error 'Can not communicate with device. Make sure it is not in use by another application and that it has a Direct Test Mode compatible firmware.' appears.
    I have still the impression that the Hardware configuration in the target electronics is not ok, but in which file (after calling uart_init()) can I check that?
    When stepping through uart_init() I see that the structure comm_params contains the right Pins for RxD and Txd, RTS and CTS are not used; the Flow Control is disabled and the baudrate parameter contains 536871040 which corresponds to 19200 Baud as far as I know. Up to the end of uart_init() (breakpoint) also the supply current is quite low, so the problem seems to come later...
    The custom_board.h contains (TX testwise moved from P0.17 to P 0.30):
    #ifndef BOARD_CUSTOM_H
    #define BOARD_CUSTOM_H
    #ifdef __cplusplus
    extern "C" {
    #include "C:\SVN\sources\SDK_17_1\modules\nrfx\hal\nrf_gpio.h"
    // LEDs definitions for HW Version 'h'
    #define TX_PIN_NUMBER 30 // testwise, normally 17
    #define HWFC false
    #ifdef __cplusplus
    #endif // BOARD_CUSTOM_H
    In the makefile I have the following settings:
    # Libraries common to all targets
    LIB_FILES += \
    # Optimization flags
    OPT = -O3 -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DBOARD_CUSTOM
    CFLAGS += -DBSP_DEFINES_ONLY
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52840_XXAA
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DBOARD_CUSTOM
    ASMFLAGS += -DBSP_DEFINES_ONLY
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52840_XXAA
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    What can I check next?
    MatthK
  • Hi MatthK,
    I am quite certain that the firmware itself is alright, unless you have changed core behavior of the DTM source code, or any of your clock sources are problematic (ie. not present or incorrectly loaded)
    The usual problem when DTM is misbehaving is physical connection issues. This can be incorrect pin connected to the external USB/UART converter for instance, or that the pin itself is physically connected to another device on the custom PCB.
    You are certain that there's no external terminal (putty, teraterm, etc) that is claiming the COM port?
    This is not a problem.
    When transmitting, you should keep the device static at one channel. This is because there's no synchronization between tester and DUT when it comes to what channel they're communicating on.
    That being said, if you can successfully start and stop a test, then the DTM is running properly.
    Have you tried programming your custom.hex file to the nRF52840-DK, then connect your FTDI to the specific pins to see if works on a DK?
    I changed the uart_init function to reflect your pin out:
    static void uart_init(void)
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              30, /*RX_PIN_NUMBER,*/
              12, /*TX_PIN_NUMBER,*/
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              APP_UART_FLOW_CONTROL_DISABLED,
              false,
              DTM_BITRATE
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_error_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    And tested this on my nRF52840-DK, and it entered DTM modes without any issues.
    Håkon
