Problem Run and Test DTM at customer hardware with nRF52840
I face at least 2 problems and need some support.
What I want to achieve is that the DTM runs at our customer hardware for radio and later on BLE certification. 3 years ago we made this with nRF52832 and it was absolutely no problem, that's why I can't really understand the problems I face now.
I have a PCA10056, a nRF52840 Dongle (PCA10059) and my customer hardware with a Taiyo Yuden module using nRF52840. The SW for the nRF52840 is built in Eclipse using gcc; for debugging I use a Segger JTracePro.
As 3 years ago I first tried to use the nRF Connect at my PC with the stick, the old nRF51 stick was compatible and worked well with nRF Connect. In the forum I read that with the nRF52840 Dongle this will not work, so I use the PC10056. I have erased this board and flashed the file direct_test_mode_pca10056.hex from SDK17.1\examples\dtm\direct_test_mode\hex. When powering this board I see a LED flickering; when selecting this board at nRF Connect (in Windows) the flickering changes a little bit; when I click at Start test the LED's behaivour changes a little bit. It seems that this works, but can I make a test with the nRF52840 Dongle for verifying?
Now coming to the main problem: I use a customer elecronics where our standard Software with BLE traffic (using SDK13; soon we will change to Zephyr) runs perfect. So I can assume that the HW is ok. Parallel to our standard project I have created a DTM project; here I use SDK17.1 to be sure that we meet the latest requirements for the radio certification. I have created a custom_board.h file which just contains:
#define LEDS_NUMBER 0
#define BUTTONS_NUMBER 0
#define RX_PIN_NUMBER 12
#define TX_PIN_NUMBER 17
#define CTS_PIN_NUMBER UART_PIN_DISCONNECTED // 8
#define RTS_PIN_NUMBER UART_PIN_DISCONNECTED // 30
#define HWFC false
RX is connected to P0.12 and Tx to P0.17.
I can build the project; when setting a breakpoint to the first line current_time = dtm_wait();in the endless-loop for (;;) the system behaves as expected. Pressing then several times F6 (Step over) will result in toggling between the mentioned current_time = dtm_wait() line and the next if(app_uart_get(&rx_byte) != NRF_SUCCESS) instruction; this seems still fine for me. When I press then 'Run' I see the supply current heavily increasing to about 4 times of the current before; when I start a test in nRF Connect I see just the same as if the customer board is switched off. When pressing 'Suspend' the program flow stops at the if(nrf_timer_event_check(..) function in dtm_wait().
A breakpoint set to the last line SystemCoreClockUpdate(); in void SystemInit(void) in system_nrf52.c is never reached...
What is here wrong?
Thanks in advance for your help
MatthK
Here is my main() function, copied from the SDK17.1:
uint32_t dtm_error_code;
uint32_t current_time;
uint32_t msb_time = 0; // Time when MSB of the DTM command was read. Used to catch stray bytes from "misbehaving" testers.
bool is_msb_read = false; // True when MSB of the DTM command has been read and the application is waiting for LSB.
uint16_t dtm_cmd_from_uart = 0; // Packed command containing command_code:freqency:length:payload in 2:6:6:2 bits.
uint8_t rx_byte; // Last byte read from UART.
dtm_event_t result; // Result of a DTM operation.
uart_init();
dtm_error_code = dtm_init();
#if defined(NRF21540_DRIVER_ENABLE) && (NRF21540_DRIVER_ENABLE == 1)
//Initialization of nRF21540 front-end BluetoothRegistered range extender chip. Do not use if your hardware doesn't support it.
APP_ERROR_CHECK(nrf21540_init());
if (dtm_error_code != DTM_SUCCESS)
// If DTM cannot be correctly initialized, then we just return.
return -1;
for (;;)
// Will return every UART pool timeout,
if (app_uart_get(&rx_byte) != NRF_SUCCESS)
// Nothing read from the UART.
continue;
if (!is_msb_read)
// This is first byte of two-byte command.
is_msb_read = true;
dtm_cmd_from_uart = ((dtm_cmd_t)rx_byte) << 8;
msb_time = current_time;
// Go back and wait for 2nd byte of command word.
continue;
// This is the second byte read; combine it with the first and process command
if (current_time > (msb_time + MAX_ITERATIONS_NEEDED_FOR_NEXT_BYTE))
// More than ~5mS after msb: Drop old byte, take the new byte as MSB.
// The variable is_msb_read will remains true.
// Go back and wait for 2nd byte of the command word.
continue;
// 2-byte UART command received.
dtm_cmd_from_uart |= (dtm_cmd_t)rx_byte;
if (dtm_cmd(dtm_cmd_from_uart) != DTM_SUCCESS)
// Extended error handling may be put here.
// Default behavior is to return the event on the UART (see below);
// the event report will reflect any lack of success.
// Retrieve result of the operation. This implementation will busy-loop
// for the duration of the byte transmissions on the UART.
if (dtm_event_get(&result))
// Report command status on the UART.
// Transmit MSB of the result.
while (app_uart_put((result >> 8) & 0xFF));
// Transmit LSB of the result.
while (app_uart_put(result & 0xFF));
  • Hi Matt,
    The nrf52840dongle, pca10059, does not have a example project specifically for DTM. This must then be manually created, as described in this thread:
    https://devzone.nordicsemi.com/guides/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial
    #define HWFC false
    What is here wrong?
    Given that you are able to debug the main application, it shows that debugging in general is working. The SystemCoreClockUpdate() is essentially an empty function updating only one variable, it might be that a optimized application updates it as a part of the .data (non zero initialized RAM) section instead.
    I am not sure what is happening here, because based on your description, the firmware runs as expected. Could you share a bit more info on where the DTM process fails on the tester side?
    How did you connect your TXD/RXD pin to the upper tester, through a USB/UART bridge?
    Håkon
  • Hi Håkon,
    the TXD/RXD pins are connected to an UART/USB bridge FT230XS; this electroncs we have already used for the first certification 3 years ago with nRF52832; so I assume that this should do also with nRF52840.
    Concerning the point of fail of the DTM process: I would like to investigate more on that problem: Is there any point in the SW where the hardware should be completely initialized? Then I could set a breakpoint and see if the supply current is still ok or increased...
    MatthK
  • Hi MatthK,
    What is the tester-side setup at your end?
    Are you using a dedicated tester, or is there a nRF-kit acting as the tester (using nRF connect for desktop->DTM application) ?
    Håkon
  • Hi Håkon,
    the DUT (Device under Test) is our target electronics containing a nrf52840 where I have the problem to make run the DTM application - a standard application with BLE (Using S140) use works perfect.
    The tester side is the PCA10056 with the flashed hex-file direct_test_mode_pca10056.hex from SDK17.1\examples\dtm\direct_test_mode\hex; as supposed I use this with nRF Connect for Desktop - DTM application.
    MatthK
  • Hi MatthK,
    Thank you for explaining the setup.
    When you flash DTM on your custom device, with P0.12/P0.17 as the RXD/TXD, the TXD should be active low (ie. high when idle), while the RXD pin will float unless connected to a TXD on the FTDI-side. You can scope the pins to see if there's any activity at all on the pins.
    You can also try different GPIOs if you want, as the default board pca10056 uses p0.12 as a button, unless you have redefined this in your boards file (note: BOARDS define must also be redefined in the Makefile).
    Easiest for quick testing different GPIOs is to just change the main.c::uart_init() function and hardcode the comm_params struct directly, and recompile.
    Are you able to setup any test in the PC application using the FTDI+custom board setup? If no, what is the error that you see on the PC side?
    Håkon
