Hi
How can I increase the connection interval of BLE radio from default value of 30mS-50mS to 600ms in NRF5340-SDK.
Hi
Hi
Hello!
The connection interval can be adjusted using Zephyr's Bluetooth API:
https://docs.zephyrproject.org/latest/reference/bluetooth/connection_mgmt.html
To learn how to use this API I would recommend having a look at the BLE throughput sample:
Notice how a bt_le_conn_param struct is defined using the BT_LE_CONN_PARAM() macro, and how that is used in the bt_conn_le_param_update() function to adjust the parameters.
Einar
Hi
Thank you very much for your information. But I want to increase the Connection interval in peripheral_uart sample code.
Would you please to guide me to modify this program to work with a different Connection interval. I defined the
bt_le_conn_paramm struct at the top and call the bt_conn_le_param_update() function in the main part of program.
It didn't work.
Hi
From my understanding, the procedure for modifying the connection interval from a peripheral should be the same, but there might be a significant delay before the changes take effect.
Is the param update function returning an error code, or are you just observing that the behavior doesn't change?
I would recommend going through the BLE throughput sample more thoroughly, in case you've missed a step of the procedure.
-Einar
Hi
I tried compiling and building the so called program with nRF Connect SDK V1.6.1 and it worked perfectly.
But by compiling and building with nRF Connect SDK V1.8.0 which is a newer version it didn't work and
the chip is resetting repeatedly.
my nRF Connect for desktop version is 3.10.0
