Hameg oscilloscope setting
Hi Guys,
I am using a the 350Mhz Analog Oscilloscope HM303-6 www.hameg.com/hm303-6.0.html to measure the voltage utilised by the board when it is transmitting data.
I have cut SB9 soldered a resistor of 10 ohms on R6. I am hving some difficulty with the settings for the oscilloscope.
I connected the probes to the nrf current measurement points, with their corresonding clips to the group . And the other side of the probes to input channel 1 and 2.
There are a bunch of settings on the oscilloscope which I am not sure of. I am getting both channel 1 and 2 as two separate signals . Shouldnt there be only one signal?
And I am confused about the settings for
  1. X-Y does both signals qualify for a x-y mode?
  2. For the input channels, it should be AC enabled, gnd disabled right?
  3. I have enabled Dual channnel with ADD IS that correct?
  4. Is there any documentation for any settings for the oscilloscope?
Sorry for the noob questions. Could someone perhaps help me with some?
Thanks a lot
    While I am not qualified to answer specific questions about your oscilloscope(please refer to Rohde&Schwarz(Hameg) for this) I can try to give a partial answer.
    1. Connect two probes to channel 1 and channel 2 of your oscilloscope
    2. Connect the probes to both sides of the 10ohm resistor, make sure that you connect both probes to ground
    3. Set the oscilloscope to X-Y mode(differential mode)
    As for settings, please refer to the manual, or contact the producer directly.
    Øyvind
  • Hi Karlsen,
    Thanks for your answer.
    I did try using Differential Mode (using Add and Inv) not X-y.And I set it to AC for both signals.
    I keep getting the same signal for any program that runs on nrf51dk the signal doesnt change at all :(
    I dont know where I am going wrong. The probes are connected to the nrf measurement points as directed in the manual.
    Do you have any idea wher eI could be going wrong?
  • Hi Karlsen,
