Problem with building a sample app at vscode
I've installed all by the book watching the installation videos and I have a problem building in VScode
when I try to build with nrf connect app window I get this error
when I try to build from terminal I get this error
PS C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry> west build -b nrf9160dk_nrf9160_ns -d buildings
Including boilerplate (Zephyr base): C:/Users/OfirA/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry
-- Using NCS Toolchain 1.8.0 for building. (C:/Users/OfirA/ncs/v1.8.0/toolchain/cmake)
-- Zephyr version: 2.7.0 (C:/Users/OfirA/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1
-- Found Python3: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Cache files will be written to: C:/Users/OfirA/ncs/v1.8.0/zephyr/.cache
-- Found dtc: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Users/OfirA/ncs/v1.8.0/toolchain/opt)
-- Found BOARD.dts: C:/Users/OfirA/ncs/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Generated zephyr.dts: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/include/generated/devicetree_unfixed.h
Merged configuration 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/prj.conf'
Configuration saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/.config'
Kconfig header saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm -  begin ===
-- Application: C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: C:/Users/OfirA/ncs/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/dts.cmake
Parsing C:/Users/OfirA/ncs/v1.8.0/zephyr/Kconfig
Loaded configuration 'C:/Users/OfirA/ncs/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm/prj.conf'
Merged configuration 'C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/Users/OfirA/ncs/v1.8.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/.config'
Kconfig header saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/include/generated/autoconf.h'
CMake Warning at C:/Users/OfirA/ncs/v1.8.0/zephyr/CMakeLists.txt:1662 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm
=== child image spm -  end ===
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[5/174] Performing build step for 'spm_subimage'
[57/218] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
FAILED: modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a
cmd.exe /C "cd . && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\cmake.exe -E rm -f modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-ar.exe qc modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a  @CMakeFiles\mbedcrypto.rsp && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-ranlib.exe modules\nrfxlib\nrfxlib\nrf_security\src\libmbedninja: build stopped: subcommand failed.        [9/174] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h                                FAILED: modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build spm/zephyr/zephyr.hex spm/zephyr/zephyr.elf spm/libspmsecureentries.a
ninja: build stopped: subcommand failed.[9/174] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
FAILED: modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build spm/zephyr/zephyr.hex spm/zephyr/zephyr.elf spm/libspmsecureentries.a cmd.exe /C "cd /D C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry\buildings\spm && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'c:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\cmake.EXE' --build 'C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry\buildings'
when I try to generate support information I get this error
any suggestion how can I solve this?
Thanks
  • Are you able to build the samples on other IDEs like SEGGER?
    -Priyanka
  • Have you installed all the extension packages?
    Did you make sure to download the latest version of nRF Command Line Tools?
    Also, if you wish to disable the assert statements, you could try adding CONFIG_ASSERT=n in the prj.conf.
    Are you still not able to Generate the Support Information?
  • Hi
    I really appreciate you trying to help
    all the extensions installed
    I tried to build from terminal as well
    PS C:\NordicStaff\myapps\blinky> west build -b nrf9160dk_nrf9160_ns -d build
    Including boilerplate (Zephyr base): C:/v1.8.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/NordicStaff/myapps/blinky
    -- Using NCS Toolchain 1.8.0 for building. (C:/v1.8.0/toolchain/cmake)
    -- Zephyr version: 2.7.0 (C:/v1.8.0/zephyr), build: v2.7.0-ncs1
    -- Found Python3: C:/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/v1.8.0/zephyr/.cache
    -- Found dtc: C:/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/v1.8.0/toolchain/opt)
    -- Found BOARD.dts: C:/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Generated zephyr.dts: C:/NordicStaff/myapps/blinky/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NordicStaff/myapps/blinky/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NordicStaff/myapps/blinky/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NordicStaff/myapps/blinky/build/zephyr/dts.cmake
    Parsing C:/v1.8.0/zephyr/Kconfig
    Loaded configuration 'C:/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'C:/NordicStaff/myapps/blinky/prj.conf'
    Configuration saved to 'C:/NordicStaff/myapps/blinky/build/zephyr/.config'
    Kconfig header saved to 'C:/NordicStaff/myapps/blinky/build/zephyr/include/generated/autoconf.h'
    -- Found assembler: C:/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
    -- Application: C:/v1.8.0/nrf/samples/spm
    -- Found BOARD.dts: C:/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: C:/v1.8.0/nrf/samples/spm/nrf9160dk_nrf9160.overlay
    -- Generated zephyr.dts: C:/NordicStaff/myapps/blinky/build/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NordicStaff/myapps/blinky/build/spm/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NordicStaff/myapps/blinky/build/spm/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NordicStaff/myapps/blinky/build/spm/zephyr/dts.cmake
    Loaded configuration 'C:/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
    Merged configuration 'C:/v1.8.0/nrf/samples/spm/prj.conf'
    Merged configuration 'C:/v1.8.0/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
    Merged configuration 'C:/v1.8.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/NordicStaff/myapps/blinky/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/NordicStaff/myapps/blinky/build/spm/zephyr/.config'
    Kconfig header saved to 'C:/NordicStaff/myapps/blinky/build/spm/zephyr/include/generated/autoconf.h'
    CMake Warning at C:/v1.8.0/zephyr/CMakeLists.txt:1662 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/NordicStaff/myapps/blinky/build/spm
    -- Configuring done
    -- Generating done
    cmd.exe /C "cd . && C:\v1.8.0\toolchain\opt\bin\cmake.exe -E rm -f modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a && C:\v1.8.0\toolchain\opt\bin\arm-none-eabi-ar.exe qc modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a  @CMakeFiles\mbedcrypto.rsp && C:\v1.8.0\toolchain\opt\bin\arm-none-eabi-ranlib.exe modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a && cmd.exe /C "cd /D C:\NordicStaff\myapps\blinky\build\spm\modules\nrfxlib\nrfxlib\nrf_security\src && C:\v1.8.0\toolchain\opt\bin\cmake.exe -DCMAKE_AR=C:/v1.8.0/toolchain/opt/bin/arm-none-eabi-ar.exe -DLIBRARY=C:/NordicStaff/myapps/blinky/build/spm/modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a -DFOLDER=C:/NordicStaff/myapps/blinky/build/spm/modules/nrfxlib/nrfxlib/nrf_security/src/objects/cc3xx -P C:/v1.8.0/nrfxlib/nrf_security/cmake/archive_folder.cmake""
    'cmd.exe' is not recognized as an internal or external command,
    operable program or batch file.
    [9/174] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    cmd.exe /C "cd /D C:\NordicStaff\myapps\blinky\build\spm && C:\v1.8.0\toolchain\opt\bin\cmake.exe --build . --"
    FATAL ERROR: command exited with status 1: 'c:\v1.8.0\toolchain\opt\bin\cmake.EXE' --build 'C:\NordicStaff\myapps\blinky\build'
      I have the latest nRF tools
    I think maybe the main problem is because of this "'cmd.exe' is not recognized as an internal or external command,
    ninja: build stopped: subcommand failed."
    not sure
    environment variable looks ok
    Really don't know what to do...
    I think I will abandon VScode and use Segger instead Disappointed
