I've installed all by the book watching the installation videos and I have a problem building in VScode
when I try to build with nrf connect app window I get this error
when I try to build from terminal I get this error
PS C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry> west build -b nrf9160dk_nrf9160_ns -d buildings -- west build: generating a build system Including boilerplate (Zephyr base): C:/Users/OfirA/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake -- Application: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry -- Using NCS Toolchain 1.8.0 for building. (C:/Users/OfirA/ncs/v1.8.0/toolchain/cmake) -- Zephyr version: 2.7.0 (C:/Users/OfirA/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1 -- Found Python3: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.12.0", minimum required is "0.7.1") -- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0 -- Cache files will be written to: C:/Users/OfirA/ncs/v1.8.0/zephyr/.cache -- Found dtc: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (C:/Users/OfirA/ncs/v1.8.0/toolchain/opt) -- Found BOARD.dts: C:/Users/OfirA/ncs/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts -- Generated zephyr.dts: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/include/generated/devicetree_unfixed.h Merged configuration 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/prj.conf' Configuration saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/.config' Kconfig header saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.2.1 -- The CXX compiler identification is GNU 9.2.1 -- The ASM compiler identification is GNU -- Found assembler: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe Changed board to secure nrf9160dk_nrf9160 (NOT NS) === child image spm - begin === Including boilerplate (Zephyr base): C:/Users/OfirA/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake -- Application: C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm -- Using NCS Toolchain 1.8.0 for building. (C:/Users/OfirA/ncs/v1.8.0/toolchain/cmake) -- Zephyr version: 2.7.0 (C:/Users/OfirA/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1 -- Found Python3: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.12.0", minimum required is "0.7.1") -- Board: nrf9160dk_nrf9160, Revision: 0.7.0 -- Cache files will be written to: C:/Users/OfirA/ncs/v1.8.0/zephyr/.cache -- Found dtc: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (C:/Users/OfirA/ncs/v1.8.0/toolchain/opt) -- Found BOARD.dts: C:/Users/OfirA/ncs/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts -- Found devicetree overlay: C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm/nrf9160dk_nrf9160.overlay -- Generated zephyr.dts: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/include/generated/device_extern.h -- Including generated dts.cmake file: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/dts.cmake Parsing C:/Users/OfirA/ncs/v1.8.0/zephyr/Kconfig Loaded configuration 'C:/Users/OfirA/ncs/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig' Merged configuration 'C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm/prj.conf' Merged configuration 'C:/Users/OfirA/ncs/v1.8.0/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf' Merged configuration 'C:/Users/OfirA/ncs/v1.8.0/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/.config' Kconfig header saved to 'C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.2.1 -- The CXX compiler identification is GNU 9.2.1 -- The ASM compiler identification is GNU -- Found assembler: C:/Users/OfirA/ncs/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe CMake Warning at C:/Users/OfirA/ncs/v1.8.0/zephyr/CMakeLists.txt:1662 (message): __ASSERT() statements are globally ENABLED -- Configuring done -- Generating done -- Build files have been written to: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings/spm === child image spm - end === Dropping partition 'nrf_modem_lib_trace' since its size is 0. -- Configuring done -- Generating done -- Build files have been written to: C:/Users/OfirA/Documents/NordicStaff/Apps/FirstTry/buildings -- west build: building application [5/174] Performing build step for 'spm_subimage' [57/218] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a FAILED: modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a cmd.exe /C "cd . && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\cmake.exe -E rm -f modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-ar.exe qc modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a @CMakeFiles\mbedcrypto.rsp && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\arm-none-eabi-ranlib.exe modules\nrfxlib\nrfxlib\nrf_security\src\libmbedninja: build stopped: subcommand failed. [9/174] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h FAILED: modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build spm/zephyr/zephyr.hex spm/zephyr/zephyr.elf spm/libspmsecureentries.a ninja: build stopped: subcommand failed.[9/174] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h FAILED: modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build spm/zephyr/zephyr.hex spm/zephyr/zephyr.elf spm/libspmsecureentries.a cmd.exe /C "cd /D C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry\buildings\spm && C:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\cmake.exe --build . --" ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'c:\Users\OfirA\ncs\v1.8.0\toolchain\opt\bin\cmake.EXE' --build 'C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry\buildings' PS C:\Users\OfirA\Documents\NordicStaff\Apps\FirstTry>
when I try to generate support information I get this error
any suggestion how can I solve this?
Thanks
