UARTE not working when specific pins are used
I'm observing a strange behavior with the UARTE peripherals on our nrf52840 based board when I'm trying to use a specific pin as TX.
In particular, I'm actually using the UARTE instance 1 with the CLI library without any problems and I want to use the UARTE instance 0 to talk with another MCU.
When we designed the board we chose to put the TX line from the nrf52840 on the P1.11 simply by picking one of the available pins on the chip.
With this configuration, we are not able to send any data to the other MCU, even attaching the oscilloscope to the TX line we can't see any activity on the TX line.
We tried to implement the UART communication using the "APP_UART" driver and the "LIBUARTE" but in both cases, the results are the same. The fun fact is that if we change the TX pin to another which is simply connected to a pad on the board (e.g. P1.12) we see activity with the oscilloscope. Even worse, if we change the TX pin used with the CLI library to P1.11, we can see the right data on the TX line!
We also tried to swap the UARTE instances used by the CLI and the MCU communication but still, the TX line is not working when we use the P1.11 pin.
Any suggestions?
P.S: We are actually using the nrf5 SDK for Thread and Zigbee v4.0.0.
