CCM->EVENTS_ERROR ( Deprecated ) ?
Hello !
I can see this error event is deprecated.
What other registers can be used if any error occurs during on-fly encryption/decryption process ?
In case of RX , MIC error is available only.
Eugene
    To check for MIC errors you have the MICSTATUS register, which holds the result of the MIC change from the previous decryption operation. Note that the EVENTS_ERROR exists even if it is marked as deprecated (and is also present even in the newer nRF5340).
  • Hi !
    Basically encryption process expected to be error free always ?
    To what event EVENTS_ERROR will be replaces ?
    Eugene
  • Hi Eugene,
    Yes, that is the case. It should not normally fail, and if it does for some odd reason (like a bug in your firmware causing it to manipulate the source buffer while the operation is ongoing for instance), there is no way to detect that (other than the ERROR event).
    There is no replacement for it. If you need it, you can use it even if it is marked as deprecated.
  • Hi Einar !
    Thank you !
    In case of encrypt, MIC status for some reason is set to 1. Is this OK ?
    Can ICACHE be enabled if on-fly operations are in use , it might effect of source buffer ?
    Can NRF_CCM->INPTR and OUTPTR be mapped to the same buffer in memory, or they really should be different ? Even In buffer is no need any more.
    What about RFU byte ( S1) ? Looks like  if on-fly mode is enabled, it must be present.
    S1LEN and S1INC in PCFN0 should be > 0
    Is this so ?
    Eugene
  • Hi Eugene,
    The MIC Status register should only be updated by a decryption operation, where the MIC is checked. Did you have a previously failed decrypt operation failed? In any case, the MIC Status has no relevance for encrypting operations so there is no reason to check it after an encryption operation.
    I do not see how that can have any consequences for the CCM peripheral, so that should be no problem.
    I do not immediately see a reason why INPTR and OUTPTR cannot be identical, and have not found any indication it should be problematic. This is not the primary use case though so it may not have been well tested. Also note that as you asked about on-the-fly encryption, note that the OUTPTR must point to the same location as the PACKETPTR register in the RADIO.
    This depends on the configuration of the RADIO peripheral (PCNF0 is a configuration register in the RADIO) and is not directly related to the CCM (other than that it passes the data on).
