Testing variations of int num_events & k_timeout_t timeout arguments in k_poll API for "spi_transceive_async"
Let me just briefly state that I have referred to required documentation and also executed spi_transceive_async() test, at zephyr\tests\drivers\spi\spi_loopback.
So request to kindly not suggest going back to documentation or trying sample program.
My question is I want to test  variations of int num_events & k_timeout_t timeout arguments in k_poll API for "spi_transceive_async".
As in what happens if i vary num_events  & what happens  if i vary timeout ...?
And how can I get this variation to reflect on "spi_transceive_async"..?
I need to know how to vary and test the sample code at zephyr\tests\drivers\spi\spi_loopback:
As In,
#if (CONFIG_SPI_ASYNC)
static struct k_poll_signal async_sig = K_POLL_SIGNAL_INITIALIZER(async_sig);
static struct k_poll_event async_evt =
	K_POLL_EVENT_INITIALIZER(K_POLL_TYPE_SIGNAL,
				 K_POLL_MODE_NOTIFY_ONLY,
				 &async_sig);
static K_SEM_DEFINE(caller, 0, 1);
K_THREAD_STACK_DEFINE(spi_async_stack, STACK_SIZE);
static int result = 1;
static void spi_async_call_cb(struct k_poll_event *async_evt,
			      struct k_sem *caller_sem,
			      void *unused)
	int ret;
	LOG_DBG("Polling...");
	while (1) {
		ret = k_poll(async_evt, 10, K_MSEC(2000)); /***** varied here ******/
		zassert_false(ret, "one or more events are not ready");
		result = async_evt->signal->result;
		k_sem_give(caller_sem);
		/* Reinitializing for next call */
		async_evt->signal->signaled = 0U;
		async_evt->state = K_POLL_STATE_NOT_READY;
static int spi_async_call(const struct device *dev,
			  struct spi_config *spi_conf)
	const struct spi_buf tx_bufs[] = {
			.buf = buffer_tx,
			.len = BUF_SIZE,
	const struct spi_buf rx_bufs[] = {
			.buf = buffer_rx,
			.len = BUF_SIZE,
	const struct spi_buf_set tx = {
		.buffers = tx_bufs,
		.count = ARRAY_SIZE(tx_bufs)
	const struct spi_buf_set rx = {
		.buffers = rx_bufs,
		.count = ARRAY_SIZE(rx_bufs)
	int ret;
	LOG_INF("Start async call");
	ret = spi_transceive_async(dev, spi_conf, &tx, &rx, &async_sig);
	if (ret == -ENOTSUP) {
		LOG_DBG("Not supported");
		return 0;
	if (ret) {
		LOG_ERR("Code %d", ret);
		zassert_false(ret, "SPI transceive failed");
		return -1;
	k_sem_take(&caller, K_FOREVER);
	if (result)  {
		LOG_ERR("Call code %d", ret);
		zassert_false(result, "SPI transceive failed");
		return -1;
	LOG_INF("Passed");
	return 0;
Thanking you in anticipation,
