Can I use both Whitelist and Scan filter in a multi-role application.
Our company is developing a product class which uses a number of NRF devices. We want to set things up in such a way where there is a single "hub" device which uses ScanFilter to read advertising data from multiple other devices, as well as having the capability to connect to those devices to change configuration settings if required. The complication is we also want the hub to be dual role, and are building a mobile application that connects to the hub via Bluetooth. Security is important for our use case so we're using LESC, one use passkeys, and whitelisting. We've been reading the documentation and are trying to understand whether there's a conflict between using a whitelist to limit the phones that can connect to the hub and using ScanFilter to read sensor data.
Many thanks.
Chitra
