I am working on an application to transfer firmware file via BLE-GATT to nRF52833.
Can you kindly suggest any sample code for me to evaluate.
Ubaid
Ubaid
Hello Edvin,
ct using the guide
With the project I build from your suggested guide:
I got the following three build/output files at build paths:
1. build/zephyr/zephyr.hex: only application
2. build/mcuboot/zephyr/zephyr.hex: only mcuboot
3. build/zephyr/merged.hex: mcuboot+application
Out of these three, I am to understand If I flash the first build file, it will flash only application.
The second build file is for mcuboot project build.
The third build file has both mcuboot+application which can be flashed.
I just need to know how to flash the second build file, that is at "build/mcuboot/zephyr/zephyr.hex"
Please suggest..?!
Thanks
So you want to know how to flash a .hex file?
You can use nRF Command Line Tools directly. You have already installed it, since West (part of nRF Connect SDK) uses it. Use the command:
nrfjprog --program build\mcuboot\zephyr\zephyr.hex --verify --sectorerase
Edvin
Thank you Edvin,
Is it fine if this ticket remains open..?
I could use your help for my DFU development.
I will leave it open.
BR,
Edvin
Hello Edvin,
I have a requirement to map SLOT-1 into external serial flash memory & fetch it through SPI interface, when mcuboot tries to swap SLOT-0 & SLOT-1.
Under the path "bootloader\mcuboot\boot\zephyr\boards" I could see that for nrf52840, some dts are provided for QSPI interface with serial flash like:
* Copyright (c) 2020 Nordic Semiconductor ASA
/delete-node/ &boot_partition;
/delete-node/ &slot0_partition;
/delete-node/ &slot1_partition;
/delete-node/ &scratch_partition;
&flash0 {
partitions {
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x000000000 0x00010000>;
slot0_partition: partition@10000 {
label = "image-0";
reg = <0x000010000 0x0000e8000>;
&mx25r64 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
slot1_partition: partition@0 {
label = "image-1";
reg = <0x000000000 0x0000e8000>;
But I couldn't understand where the APIs are present for swapping..?
I need to understand where do I make changes in mcuboot source code to make SPI access to SLOT-1 on external flash..?
Or will this work just with configurations..?
Kindly suggest or point me to understand with the changes.
