Serial LTE Modem Application (NRF9160) FOTA does not apply new update
I have the SLM application running in a custom board with uses the NRF9160. The SLM is driven an external microprocessor within the same board. Everything seems to work but FOTA will not apply the update.
Basically, we send the following commands after we confirmed successful network registration:
AT#XFOTA=8
AT#XFOTA=1,"">xxxxxx.amazonaws.com/app_update.bin"
This sequence of commands downloaded the FOTA image successfully. Then, we apply the AT#RESET command and this is what we are seeing from RTT
00> *** Booting Zephyr OS build v2.7.0-ncs1 ***
00> I: Starting bootloader
00> I: Primary image: magic=good, swap_type=0x4, copy_done=0x1, image_ok=0x1
00> I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
00> I: Boot source: none
00> I: Swap type: test
00> D: erasing trailer; fa_id=3
00> D: initializing status; fa_id=3
00> D: writing swap_info; fa_id=3 off=0x6ffd8 (0x7ffd8), swap_type=0x2 image_num=0x0
00> D: writing swap_size; fa_id=3 off=0x6ffd0 (0x7ffd0)
00> D: writing magic; fa_id=3 off=0x6fff0 (0x7fff0)
00> D: erasing trailer; fa_id=7
00> D: writing copy_done; fa_id=3 off=0x6ffe0 (0x7ffe0)
00> I: Bootloader chainload address offset: 0x10000
00> I: Jumping to the first image slot
00> I: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3
00> I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
00> I: Swap type: revert
00> D: writing image_ok; fa_id=7 off=0x6ffe8 (0xeffe8)
00> D: writing swap_size; fa_id=7 off=0x6ffd0 (0xeffd0)
00> D: writing magic; fa_id=7 off=0x6fff0 (0xefff0)
00> D: writing swap_info; fa_id=3 off=0x6ffd8 (0x7ffd8), swap_type=0x4 image_num=0x0
00> D: writing image_ok; fa_id=3 off=0x6ffe8 (0x7ffe8)
After this, the SLM gets run again and we read the following response from the application:
b'\x00Ready\r\n'
b'\r\n'
b'#XFOTA: 5,1,-9\r\n'
This basically indicates failure in the FOTA process. Can someone please help.
    Given that it downloads, resets and prints this:
    It means that mcuboot recognizes this image, but on the very next sequence:
    You are essentially trying to boot the new image, and you're reset again, where it reverts to the original image.
    This can happen if the configuration differs from what mcuboot expects, for instance in the flash layout of the secondary/primary slot.
    Could you share details on your original projects "partitions.yml" and/or "pm_static.yml", as well as the "update project"'s partition layout?
    It is very important that you follow the partition layout of the original image for all update images.
    Håkon
  • Thank you for pointing that one. After looking at those files you requested, looks like I need to re-implement the board files since I had it initially implemented using NCS v1.5.0.
    I will get back to you regardless if it fixed the issue or not.
  • Let me know if you run into any issues, or have questions!
    Håkon
  • Im getting now this error:
    00> I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    00> I: Swap type: none
    00> I: Bootloader chainload address offset: 0xc000
    00> E: Protect mcuboot flash failed, cancel startup.
    And here is the content of the pm_static.yml file:
    app: {address: 0x18200, size: 0x5ae00}
    mcuboot:
      address: 0x0
      placement:
        before: [mcuboot_primary]
    mcuboot_pad:
      address: 0xc000
      placement:
        align: {start: 0x1000}
        before: [mcuboot_primary_app]
    mcuboot_primary:
      address: 0xc000
      span: [spm, mcuboot_pad, app]
    mcuboot_primary_app:
      address: 0xc200
      span: [app, spm]
    mcuboot_scratch:
      address: 0xde000
      placement:
        after: [app]
    mcuboot_secondary:
      address: 0x75000
      placement:
        after: [mcuboot_primary]
      share_size: [mcuboot_primary]
    EMPTY_0:
      address: 0xfc000
    settings_storage:
      address: 0xfe000
      placement:
        after: [mcuboot_scratch]
    spm:
      address: 0xc200
      inside: [mcuboot_primary_app]
      placement:
        before: [app]
    And for "board_partition_conf.dts"
    &slot0_partition {
        reg = <0x00010000 0x30000>;
    &slot0_ns_partition {
        reg = <0x00040000 0x40000>;
    &slot1_partition {
        reg = <0x00080000 0x30000>;
    &slot1_ns_partition {
        reg = <0x000b0000 0x40000>;
    /* Default SRAM planning when building for nRF9160 with
     * ARM TrustZone-M support
     * - Lowest 64 kB SRAM allocated to Secure image (sram0).
     * - 64 kB SRAM reserved for and used by the BSD socket
     *   library.
     * - Upper 128 kB allocated to Non-Secure image (sram0_ns).
    &sram0_s {
        reg = <0x20000000 DT_SIZE_K(64)>;
    &sram0_bsd {
        reg = <0x20010000 DT_SIZE_K(64)>;
    &sram0_ns {
        reg = <0x20020000 DT_SIZE_K(128)>;
