I know that it is possible to make 4 PWM outputs, but I need to generate 5. I will be using SoftDevice 110 and BLE. Is there any possible way to generate a 5th PWM output?
Any advice would be much appreciated.
We have 4 compare events per timer instance, for each of these 4 one will be used as a reset. That means that we're left with three possible outputs per timer. In operation alongside the SoftDevice we will have access to two timers, this gives us a total of 6 outputs.
The problem is that we only have 4 GPIOTE slots, which means that you will not get reliable PWM output, this might be fine if you want to control a LED or simple motor.
For help on implementation search google for "bit bang pwm", and there should be some useful results.
Øyvind
Ok, I see. I don't think I will try to add a 5th pwm output then. Thanks for helping!
