clarification of PAN#73 (v3 TIMER PPI sleep issues) workaround
The workaround for nRF51822 PAN#73 specifies setting an undocumented register at offset 0x0C0C of the timer peripheral to 1 prior to TASKS_START, and clearing it after TASKS_STOP.
Two questions:
  • The description says "Routing TASKs...using the PPI and at the same time going into sleep mode". "At the same time" is unclear. Does the anomaly only apply when entering sleep immediately after configuring a PPI, or is it an issue any time the CPU is in sleep mode while the PPI is enabled? (I assume the latter, but the former is a valid interpretation.)
  • What is the impact of the register at that address being set to 1 when the timer is stopped? is shutdown? Increased current consumption? Anything else?
And a request: in future SDKs and documentation please add a register declaration in the NRF_TIMER_Type structure that can be used when implementing the workaround. Direct assignments to undocumented absolute addresses raise red flags in code review (and thus introduce the need for comments that contain links to the PAN description that justifies for their presence).
