LOCOMP function failed when reference level being changed periodically
Dear all,
I ran LPCOMP example from SDK16 on nRF52 DK and it works just fine.
But I've occurred some problem modifying reference voltage. I init the lpcomp the same way as SDK shows, then I manually triggerred a SAMPLE TASK to get the compare RESULT. I need to distinguish the input voltage into three levels so I need to compare the analog input with two different reference. So I do nrf_drv_lpcomp_uninit() and run nrf_drv_lpcomp_init() with another refence voltage. But the comparator result will remain 0 no matter what input is appllied on input pin.
If I initialize the lpcomp with fixed refence voltage and not doing uninit and init during system running, the comparator works well. So I assume there must be something wrong with the uninit part?
Code is shown as follows and your help is appreciated!
static void batt_level_deinit()
	nrf_drv_lpcomp_uninit();
static void lpcomp_event_handler(nrf_lpcomp_event_t event)
static void level_set(nrf_lpcomp_ref_t ref, nrf_lpcomp_detect_t det)	//NRF_LPCOMP_REF_SUPPLY_4_8  NRF_LPCOMP_DETECT_UP
    uint32_t	err_code;
    nrf_drv_lpcomp_config_t config = NRF_DRV_LPCOMP_DEFAULT_CONFIG;
    config.input = NRF_LPCOMP_INPUT_0;
		config.hal.hyst = NRF_LPCOMP_HYST_50mV;
		config.hal.reference = ref;
		config.hal.detection = det;
    // initialize LPCOMP driver, from this point LPCOMP will be active and provided
    // event handler will be executed when defined action is detected
    err_code = nrf_drv_lpcomp_init(&config, lpcomp_event_handler);
		nrf_drv_lpcomp_enable();
static uint8_t get_comp_result()
	NRF_LPCOMP->TASKS_SAMPLE=1;
	while(!nrf_lpcomp_event_check(NRF_LPCOMP_EVENT_READY));
	return NRF_LPCOMP->RESULT;
static uint8_t batt_level_ergodic()
	level_set(NRF_LPCOMP_REF_SUPPLY_13_16, NRF_LPCOMP_DETECT_DOWN);
	if(get_comp_result())
		batt_level_deinit();
		return 3;
//	batt_level_deinit();
//	level_set(NRF_LPCOMP_REF_SUPPLY_9_16, NRF_LPCOMP_DETECT_DOWN);
//	if(get_comp_result())
//		return 2;
//	level_set(NRF_LPCOMP_REF_SUPPLY_3_16, NRF_LPCOMP_DETECT_DOWN);
//		return 1;
	return 0;
/****************** MAIN *********************/
int main()
	uint32_t result;
	NRF_LOG_INIT(NULL);
	NRF_LOG_INFO("start!\r\n");
	while(1)
		result = batt_level_ergodic();
		NRF_LOG_INFO("%d\r\n", result);
		nrf_delay_ms(1000);
		NRF_LOG_FLUSH();
    I wasn't able to reproduce this on my side, but I tried modifying the lp-comp example by adding your level_set() and see if it was able to change the reference voltage, which it did. Here is the code I used:
    #define WAVE_ON_PIN_NUMBER 2
    static volatile uint32_t voltage_falls_detected = 0;
    static volatile uint32_t voltage_falls_total    = 0;
     * @brief LPCOMP event handler is called when LPCOMP detects voltage drop.
     * This function is called from interrupt context so it is very important
     * to return quickly. Don't put busy loops or any other CPU intensive actions here.
     * It is also not allowed to call soft device functions from it (if LPCOMP IRQ
     * priority is set to APP_IRQ_PRIORITY_HIGH).
        if (event == NRF_LPCOMP_EVENT_DOWN)
            bsp_board_led_invert(BSP_BOARD_LED_0); // just change state of first LED
            voltage_falls_detected++;
            voltage_falls_total++;
     * @brief Print out detection statistics.
    static void print_statistics(void)
        while (voltage_falls_detected)
            voltage_falls_detected--;
            NRF_LOG_INFO("#%d fall detected", (int)voltage_falls_total);
     * @brief Initialize LPCOMP driver.
    static void lpcomp_init(void)
        uint32_t                err_code;
        config.input = NRF_LPCOMP_INPUT_2;
        uint32_t	err_code;
        nrf_gpio_cfg_output(WAVE_ON_PIN_NUMBER); // on this pin 2Hz wave will be generated
    #ifdef BSP_BUTTON_0
        // configure pull-up on first button
        nrf_gpio_cfg_input(BSP_BUTTON_0, NRF_GPIO_PIN_PULLUP);
        uint32_t err_code = NRF_LOG_INIT(NULL);
        lpcomp_init();
        NRF_LOG_INFO("LPCOMP driver usage example started.");
        int i = 0;
        while (true)
          if(i == 10)
              NRF_LOG_INFO("New reference voltage set to 13_16");
            if(i == 20)
              i = 0;
              NRF_LOG_INFO("New reference voltage set to 9_16");
            i++;
            print_statistics();
            bsp_board_led_on(BSP_BOARD_LED_1);
            NRF_GPIO->OUTCLR = (1 << WAVE_ON_PIN_NUMBER);
            nrf_delay_ms(100); // generate 100 ms pulse on selected pin
            print_statistics();
            bsp_board_led_off(BSP_BOARD_LED_1);
            NRF_GPIO->OUTSET = (1 << WAVE_ON_PIN_NUMBER);
            nrf_delay_ms(400);
            NRF_LOG_FLUSH();
    regards
    Jared
  • Thanks Jared,
    Your code worked.
    Meanwhile I figured out the problem of my code: "nrf_lpcomp_event_check(NRF_LPCOMP_EVENT_READY)" is not actually working, I still need to insert delay manually everytime I re-init the LPCOMP before sampling.
    Thanks!
