Multiple UART on NRF52833
Hello Everyone,
                   I am using NRF52833 in my project and I have my NRF module connected to 2 other microcontrollers on UART peripherals. The details are mentioned as below:-
1) NRF52833 connected to MCU A
   RX pin of nrf- P0.29
   TX pin of nrf- P0.28
2) NRF52833 connected to MCU B
   RX pin of nrf- P0.30
   TX pin of nrf- P0.31.
I have successfully configured connection to MCU and I am able to transmit data from NRF to MCU A and receive data on NRF from MCU A.
Now I have to add another UART in the code so as to communicate with MCU B. What will be the steps to add one more UART configuration?? What is the procedure to do so.
Thanks & Regards,
Snehal.
    You're absolutely right, the app_uart module does not work with multiple instances. It's hardcoded to use UART(E) instance 0. You can use one UART(E) peripheral with app_uart and another UART(E) peripheral with the libUARTE peripheral.
    Steps:
    1. Modify the libUARTE example in the SDK so that it uses UARTE instance 1 instead of 0. You can do this by:
      1. setting #define NRF_LIBUARTE_DRV_UARTE1 to 1 in the sdk_configh.h file.
      2. Initialize UARTE 1 in main.c by NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 1, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
      3. Build the example and see if it works as expected.
    2. Merge the modified libuarte example with the app_uart example.
      1. Compare the two sdk_config.h files and include everything that is not already included in the app_uart config file. Use the compare option in VS code.
      2. Add all project source files and paths that hasn't already been included. See this.
    3. Test the example.
    regards
    Jared
  • Hi Jared,
               Thanks for your reply. I followe dyour instructions and did the changes as follows:-
    In sdk_config.h
    ADDED LIBUARTE CONFIG
    // <q> NRF_LIBUARTE_ASYNC_WITH_APP_TIMER - nrf_libuarte_async - libUARTE_async library
    #ifndef NRF_LIBUARTE_ASYNC_WITH_APP_TIMER
    #define NRF_LIBUARTE_ASYNC_WITH_APP_TIMER 1
    // <h> nrf_libuarte_drv - libUARTE library
    // <q> NRF_LIBUARTE_DRV_HWFC_ENABLED - Enable HWFC support in the driver
    #ifndef NRF_LIBUARTE_DRV_HWFC_ENABLED
    #define NRF_LIBUARTE_DRV_HWFC_ENABLED 0
    // <q> NRF_LIBUARTE_DRV_UARTE0 - UARTE0 instance
    #ifndef NRF_LIBUARTE_DRV_UARTE0
    #define NRF_LIBUARTE_DRV_UARTE0 0
    // <q> NRF_LIBUARTE_DRV_UARTE1 - UARTE1 instance
    #ifndef NRF_LIBUARTE_DRV_UARTE1
    #define NRF_LIBUARTE_DRV_UARTE1 1
    // <e> NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED
    #define NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED 1
    // <o> NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL - Default Severity level
    #ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL
    #define NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL 3
    // <o> NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR - ANSI escape code prefix.
    #ifndef NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR
    #define NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR 0
    // <o> NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR - ANSI escape code prefix.
    #ifndef NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR
    #define NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR 0
    In uart.c added code for uarte
    typedef struct {
    uint8_t * p_data;
    uint32_t length;
    } buffer_t;
    NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
    static volatile bool m_loopback_phase;
    void sys_uart2_init(void);
    void libuarte_event_handle(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
    case NRF_LIBUARTE_ASYNC_EVT_ERROR:
    bsp_board_led_invert(0);
    case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
    ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
    if (ret == NRF_ERROR_BUSY)
    buffer_t buf = {
    .p_data = p_evt->data.rxtx.p_data,
    .length = p_evt->data.rxtx.length,
    ret = nrf_queue_push(&m_buf_queue, &buf);
    APP_ERROR_CHECK(ret);
    bsp_board_led_invert(1);
    m_loopback_phase = true;
    case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
    if (m_loopback_phase)
    nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
    if (!nrf_queue_is_empty(&m_buf_queue))
    buffer_t buf;
    ret = nrf_queue_pop(&m_buf_queue, &buf);
    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
    bsp_board_led_invert(2);
    ret_code_t err_code;
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
    .tx_pin = UART2_TX_PIN_NUMBER,
    .rx_pin = UART2_RX_PIN_NUMBER,
    .baudrate = NRF_UARTE_BAUDRATE_9600,
    .parity = NRF_UARTE_PARITY_EXCLUDED,
    .hwfc = NRF_UARTE_HWFC_DISABLED,
    .timeout_us = 100,
    .int_prio = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, libuarte_event_handle, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
    //err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
    //APP_ERROR_CHECK(err_code);
    after adding the code i tried to compile and I am getting error: -
    How to solve this error?
  • Seems like you already use UARTE1 in your project? Have you already initialized UARTE1 somewhere else in your code?
  • I disabled this in sdk_config.h. Had enabled it according to our previous discussion. Now again i have disabled it. I have attached my sdk_config file. 3566.sdk_config.h
    #ifndef UART1_ENABLED
    #define UART1_ENABLED 0
    // <q> UART1_CONFIG_USE_EASY_DMA - Default setting for using EasyDMA
    #ifndef UART1_CONFIG_USE_EASY_DMA
    #define UART1_CONFIG_USE_EASY_DMA 0
    #ifndef APP_UART_DRIVER_INSTANCE
    #define APP_UART_DRIVER_INSTANCE 1
    The SDK config should look somewhat similar to this.
    5415.sdk_config.h
