Getting Reset Reason as Watchdog Reset after image update
Hi Team
We are using the Nrf52840 module for our dev purpose. As part of image update, we Erasing and load the new image to the chip by using Nrf connect App with Jlink Debugger.
After flashing is done, board is Reset and running, at that time when read the  below register, it is always showing reset reason as Watchdog Reset "DOG".
        NRF_POWER->RESETREAS
Without Image update when we power on reset the board, it is showing the Reset reason as  "-RESETPIN".
So when ever we update the image and run the board , by default the Reset reason it should  show "-DOG", is this is expected only, some issue is there is by default. Could anyone give clarity on this one.
Srinivas.V
  • Hi Kenneth,
    Thanks for your reply.
    we have followed the sequence what you have suggested in previous reply in point 2.
    2. Completely erase the board, POWER CYCLE THE BOARD,  and reflash it again and after that we have Read and output and clear the Reset Reason. In this case the out put showing Reset Reason as "-RESETPIN" , not as "DOG".
    If we do the Flash erase, Reflash the New Image and POWER CYCLE THE BOARD, in this sequence we are getting the Reset Reason as "-DOG"
    What is difference between these two sequences, if we do flash without power cycle what's happened inside the Registers. Can you please give me or explain the difference.
    Srinivas.V
  • (Sorry if this reply doesn't align with last message)
    Reset is not always what you expect; to be sure power-cycle and power on at least twice before looking at the reset reason to prove the scenarion you describe, as a single power cycle often generates a reset before you get to user code which looks at the reset reason and therefore shows the wrong reset reason. Alternatively place the code which captures the reset reason at the start of the following function, as this function often generates a reset (for example to apply reset pin programming) after a flash erase and reprogram. This function runs before main()
    // User information configuration registers (UICR) are written in the same way as Flash. After UICR has been
    // written, UICR registers that configure HW (offset 0x200 or higher), including REG0 & Reset pin, require
    // a reset to take effect since UICR is only read during startup.
    void SystemInit(void)
        blah-blah
        // UICR changes require a reset to be effective
        NVIC_SystemReset();
  • HI Kenneth,
    I got your point, some times after a flash erase and reprogram also generates a reset condition. As explained to take the effect of UICR registers also some times needs Reset.
    But specifically getting the Reset Reason as "DOG" after flash erase or reprogramming is there any specific reason, like which is causing this one like UICR registers or some other source.
    Could you please provide more clarity on this one.
    Srinivas.V
  • If you enable watchdog at any time, then you need to feed/reload the watchdog, else it will timeout and trigger watchdog. This is the case even if you reflash the chip, only way to stop watchdog is a hard reset (power cycle or pin reset).
    Kenneth
  • Hi Kenneth,
    Thanks for giving support.
    As per your explanation, we have enabled the watchdog and we are refeeding at the end of while loop every time.As part of reprogramming we are erasing and reflashing, it means while erasing the complete code in flash will erase the  watchdog configuration and register settings as well .So if that is the case, after reflashing we are enabling and refeeding. So where is the gap for watchdog to trigger the timeout event in between after flashing and code start the execution. Somewhere i am getting interest on this point.
    Srinivas.v
