Getting Reset Reason as Watchdog Reset after image update
Hi Team
We are using the Nrf52840 module for our dev purpose. As part of image update, we Erasing and load the new image to the chip by using Nrf connect App with Jlink Debugger.
After flashing is done, board is Reset and running, at that time when read the  below register, it is always showing reset reason as Watchdog Reset "DOG".
        NRF_POWER->RESETREAS
Without Image update when we power on reset the board, it is showing the Reset reason as  "-RESETPIN".
So when ever we update the image and run the board , by default the Reset reason it should  show "-DOG", is this is expected only, some issue is there is by default. Could anyone give clarity on this one.
Srinivas.V
  • Hi Kenneth,
    Thanks for giving support.
    As per your explanation, we have enabled the watchdog and we are refeeding at the end of while loop every time.As part of reprogramming we are erasing and reflashing, it means while erasing the complete code in flash will erase the  watchdog configuration and register settings as well .So if that is the case, after reflashing we are enabling and refeeding. So where is the gap for watchdog to trigger the timeout event in between after flashing and code start the execution. Somewhere i am getting interest on this point.
    Srinivas.v
    How do you draw this conclusion? It's not stopped or cleared by a flash erase/eraseall operation. So you need to eraseall, then power cycle the board, then reflash.
    Kenneth
  • Hi Kenneth,
    Thanks for your reply.
    It means after flash erase/erase all operation we need to power cycle the board then reflash. After erase all operation without power cycle and with power cycle what is the difference.
    So after power cycle only it will update the WDT related UICR and other config Registers. please clarify me on this one.
    Srinivas.V
  • The watchdog peripheral is a independent peripheral, once started it will require to be fed, else it will timeout and trigger a watchdog reset. The only way to stop a watchdog is a "hard" reset (e.g power cycle). I do not understand why you are mentioning UICR, there is no dependency between UICR and watchdog.
    Kenneth
  • Hi Kenneth,
    Once again thanks for your reply.
    Yes there is no dependency between UICR and WDT and we need to feed to WDT all are fine. My doubt is,
    1. We have completely erased the flash - no WDT Settings in Flash
    2. We have reprogrammed the new Image with WDT Enabled - Flashing is done.
    3. Restarting the board means through Debugger Reset Pin.
    4. When we see the reset reason it shows as -Dog, At this stage the program still not reached the WDT Config Function, just resets the board and Reading the reset Register. in this case when and where the WDT is enabled, and why it is showing the Reset reason as -Dog.
    Srinivas.V
