Following the BLE DFU tutorial is causing errors and wont build
I am following along with the BLE DFU tutorial found here https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu but when I attempt to build it I get errors and the build fails.
CMake Error at C:\Users\jb\ncs\v1.8.0\nrf\cmake\partition_manager.cmake:562 (math):
  math cannot parse the expression: " + - ": syntax error, unexpected end of
  file (18).
  C:\Users\jb\ncs\v1.8.0\zephyr\cmake\app\boilerplate.cmake:665 (include)
  C:\Users\jb\ncs\v1.8.0\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:24 (include)
  C:\Users\jb\ncs\v1.8.0\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:35 (include_boilerplate)
  d:\ble_dfu_test2\build\CMakeLists.txt:12 (find_package)
  File "C:/Users/jb/ncs/v1.8.0/nrf/scripts/partition_manager_output.py", line 222, in <module>
    main()
  File "C:/Users/jb/ncs/v1.8.0/nrf/scripts/partition_manager_output.py", line 218, in main
    write_gpm_config(gpm_config, greg_config, name, header_file)
  File "C:/Users/jb/ncs/v1.8.0/nrf/scripts/partition_manager_output.py", line 114, in write_gpm_config
    if any('span' in x for x in gpm_config[domain][image]):
KeyError: 'mcuboot'
CMake Error at C:\Users\jb\ncs\v1.8.0\nrf\cmake\partition_manager.cmake:597 (message):
  Partition Manager GLOBAL output generation failed,
      aborting. Command: C:/Users/jb/ncs/v1.8.0/toolchain/opt/bin/python.exe;C:/Users/jbclyde/ncs/v1.8.0/nrf/scripts/partition_manager_output.py;--input-partitions;D:/Work(skillz)/minigp/proto_v1/ble_dfu_test2/build/partitions.yml;--input-regions;D:/Work(skillz)/minigp/proto_v1/ble_dfu_test2/build/regions.yml;--header-files;D:/Work;(;skillz;);/minigp/proto_v1/ble_dfu_test2/build/mcuboot/zephyr/include/generated/pm_config.h;D:/Work(skillz)/minigp/proto_v1/ble_dfu_test2/build/zephyr/include/generated/pm_config.h;--images;:mcuboot;:app
along with several warnings
warning: LOG_DEFAULT_LEVEL (defined at C:\Users\jbclyde\ncs\v1.8.0\nrf\samples\Kconfig:89,
d:\ble_dfu_test2\build\subsys\logging\Kconfig.filtering:13) was assigned the value '0' but got the value ''. Check these
unsatisfied dependencies: (LOG || LOG) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_DEFAULT_LEVEL.html and/or look up
LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: BOOTLOADER_MCUBOOT (defined at d:\ble_dfu_test2\build\Kconfig.zephyr:561) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: (!MCUBOOT) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BOOTLOADER_MCUBOOT.html and/or look up
BOOTLOADER_MCUBOOT in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: The choice symbol LOG_MODE_MINIMAL (defined at d:\ble_dfu_test2\build\subsys\logging\Kconfig.mode:45) was selected
(set =y), but no symbol ended up as the choice selection. See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_MODE_MINIMAL.html and/or look up
LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
If you can help me understand what might be wrong and how to fix it that would be appreciated. Thank you
    Could I see your prj.conf file? I suspect that you have CONFIG_MCUBOOT=y in your application, which is not correct. If you have that config, try removing it.
  • CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="Nordic_LBS"
    # Enable the LBS service
    CONFIG_BT_LBS=y
    CONFIG_BT_LBS_POLL_BUTTON=y
    CONFIG_DK_LIBRARY=y
    # Enable mcumgr.
    CONFIG_MCUMGR=y
    # Enable most core commands.
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    # Ensure an MCUboot-compatible binary is generated.
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Allow for large Bluetooth data packets.
    CONFIG_BT_L2CAP_TX_MTU=252
    CONFIG_BT_BUF_ACL_RX_SIZE=256
    # Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    # Some command handlers require a large stack.
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_UART_CONSOLE=n
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    It's not in my prj.conf, is there another place I should check?
  • I downloaded the Git folder for this tutorial and built in in an entirely new workspace and it compiled fine. I am assuming there is an issue in my VSC settings but even when i change them for my other workspace to reflect just the tutorial code it still doesn't compile. For now I will be working in a different workspace to get around this but please let me know if there are any files I can share that might help compare the difference.
  • Great to hear that you got it working!
    I am not familiar with this specific issue regarding workspaces, but I will ask around and get back to you when I know more.
  • In the old workspace, can you try deleting the build configuration, removing the application in VS Code, then re-adding the application and creating a new build configuration?
