Hello
I am implementing a battery voltage monitoring function using nrf52840. I am a beginner in hardware development. As the first step of this function, I am currently implementing a function to read the voltage value. I am using the function "es_battery_voltage_get()" to read out the data. I have a question about "data.done.p_buffer[]" in saadc_event_handler(), which is a kson of the saadc source file. In this array, the default index was 0, but when I changed it to 1, the output voltage value increased about 20 times. I had no idea what voltage was being represented. So, I was wondering if you could tell me the meaning of the variable "data.done.p_buffer[]", including that point. Thank you very much. Thank you in advance.
static void saadc_event_handler(nrf_drv_saadc_evt_t const * p_evt)
if (p_evt->type == NRF_DRV_SAADC_EVT_DONE)
nrf_saadc_value_t adc_result;
adc_result = p_evt->data.done.p_buffer[1];
m_batt_lvl_in_milli_volts =
ADC_RESULT_IN_MILLI_VOLTS(adc_result) + DIODE_FWD_VOLT_DROP_MILLIVOLTS;
LemonCake
