Hello, guys.
I am trying to port some existing piece of code that benefints from Nordic's SDK into Zephyr OS environment. The part of the code is using I2C bus to communicate with the sensor (CST816S touch controller).
To properly read the content of CST816S register, the following I2C-related lines are used:
ret = nrfx_twi_tx(&m_twi_0, 0x15, w2_data, 1, true); ... ret = nrfx_twi_rx(&m_twi_0, 0x15, w2_data, 1);
The first line of code from above (nrfx_twi_tx(&m_twi_0, 0x15, w2_data, 1, true);) is I2C transfer without STOP stop condition generated at the end of the transfer (because the last argument is set to true).
I was initially trying to use native I2C drivers from Zephyr OS but was unable to find appropriate counterpart for nrfx_twi_tx(&m_twi_0, 0x15, w2_data, 1, true) type of I2C transfer. I used i2c_write_read() API that comes from Zephyr environment hoping that it will replace tx/rx requst from the above lines of code but to no avail.
I am now trying to figure out how to use Nordic's nrfx_twi drivers in Zephyr environment.
Putting the following lines in prj.conf file:
CONFIG_I2C=y CONFIG_I2C_NRFX=y CONFIG_NRFX_TWI=y CONFIG_NRFX_TWI0=y CONFIG_NRFX_TWI1=y
and trying to initialize I2C peripheral with:
const nrfx_twi_config_t config_A = {
.scl = TWI_A_SCL_PIN,
.sda = TWI_A_SDA_PIN,
.frequency = NRF_TWI_FREQ_400K,
.interrupt_priority = 1, //APP_IRQ_PRIORITY_HIGH,
.hold_bus_uninit = false
err_code = nrfx_twi_init(&m_twi_0, &config_A, NULL, NULL);
LOG_INF("nrfx_twi_init(m_twi0): 0x%X", err_code);
nrfx_twi_enable(&m_twi_0);
does not work properly. nrfx_twi_init() function returns 0xBAD0005 (NRFX_ERROR_INVALID_STATE).
I also tried to include the following part during the initialization process (before nrfx_twi_init() function):
IRQ_CONNECT(DT_IRQN(DT_NODELABEL(i2c0)),
DT_IRQ(DT_NODELABEL(i2c0), priority),
nrfx_isr, nrfx_twi_0_irq_handler, 0);
but at that point, I got the following compilation error:
gen_isr_tables.py: error: multiple registrations at table_index 3 for irq 3 (0x3) Existing handler 0x6773, new handler 0x6773 Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
What I am missing here, what would be the proper way of using Nordic's nrfx_twi driver in Zephyr environment?
Is there any appropriate Zephyr I2C counter-part for this type of I2C transfers -> nrfx_twi_tx(&m_twi_0, 0x15, w2_data, 1, true)?
Thanks in advance for your time and efforts. It is really appreciated.
Looking forward to reading from you.
Sincerely,
Bojan.
