I'm testing a simple application based on the UDP example. It samples some peripherals and ADC channels, these values are then packed into a CoAP message. This CoAP message is sent trough the socket api, and the application waits for a response:
- Create CoAP message
- Send CoAP message using send(), no flags
- Use poll() to poll for response
- recv() when poll indicated there is something to read
- repeat after a couple of seconds
This works fine with RAI disabled, but the power draw is to high, the response usually comes after 1-2 seconds, and with the network RCC timeout of 10 seconds a lot of time is wasted waiting for nothing. Now I want to enable RAI, I came across several options:
- Use
lte_lc_rai_param_set("3"); lte_lc_rai_req(true); - Use AT%RAI
- Use AT%XRAI
- Use
err = setsockopt(sock, SOL_SOCKET, SO_RAI_ONE_RESP, NULL, 0);
Which one to use? I'm using modem FW 1.3.1 and sdk 1.7.0, all on NB-IOT.
