QSPI Not waking from deep sleep on startup
In SDK 1.9.0 i saw that QSPI deep power down was implemented and i can confirm that that works using the below code.  The issue I see is that if the device is in deep power down mode and then the device is rebooted and power is maintained in my case through the debugger the device does not reinitialize so this kind of defeats the use of power management.   I also see that the call to get device binding returns a 0 so I can not make a call to run a resume action.
Previous to this I was using the device as SPI NOR and it restarted just fine.  I see that when powered down my board is running at the same power level with both drivers idle.  Is this the wrong code or am I missing something?  I see that dpd is only implemented in the nrf_qspi_nor.c qspi_nor_pm_action function.
Thanks
Ed
#if (CONFIG_NORDIC_QSPI_NOR - 0) || DT_NODE_HAS_STATUS(DT_INST(0, nordic_qspi_nor), okay)
g_qspi_dev = device_get_binding(DT_LABEL(DT_INST(0, nordic_qspi_nor)));
pm_device_action_run(g_qspi_dev,PM_DEVICE_ACTION_SUSPEND);
