Using the "mqtt_simple" example I found that the data_publish () function does not work for a timer handler.
In the case of the example below, when the data_publish () function is called by the timer, a memory violation occurs and the system is reset.
How can I resolve this issue where the data_publish () function can be called by the timer?
Neculai
s
static void button_handler(uint32_t button_states, uint32_t has_changed)
if (has_changed & button_states &
BIT(CONFIG_BUTTON_EVENT_BTN_NUM - 1)) {
int ret;
ret = data_publish(&client, // OK, Working well !
MQTT_QOS_1_AT_LEAST_ONCE,
CONFIG_BUTTON_EVENT_PUBLISH_MSG,
sizeof(CONFIG_BUTTON_EVENT_PUBLISH_MSG)-1);
if (ret) {
LOG_ERR("Publish failed: %d", ret);
static void data_interval_timer_handler(struct k_timer *timer)
ARG_UNUSED(timer);
int ret;
ret = data_publish(&client, // Error !!, system violation !!
if (ret) {
in main() function
k_timer_start(&data_interval_timer, // start timer, OK!
K_MINUTES(1),
K_MINUTES(1));
