Can NCS-ADC convert microphone analog signal into digital signal?
Hello
NCS1.8.0   Windows10  X64;
Can [v1.8.0\zephyr\tests\drivers\adc] convert microphone analog signal into digital signal? for I2S 8bit 8kHz
thanks
Best Regards
    Yes, you may use the SAADC peripheral to generate samples from a microphone and then transfer them elsewhere using the I2S peripheral, sure.
    You should configure the SAADC to do periodic sampling at the required frequency through connecting it to a TIMER instance through the PPI peripheral - i.e use the PPI peripheral to make the TIMER CAPTURE/COMPARE event trigger the SAMPLE task of the SAADC, and then have the SAADC's DONE event handler stage the buffer for transfer over I2S.
    Karl
