MQTT, using EC PRIVATE KEY to connect to a broker
I am using P822601 board (with nRF9160 chip).
Sample project "Serial lte modem" (SDK 1.8).
Faced a problem related to the inability to connect to the MQTT broker when using "EC PRIVATE KEY" via LTE Link Monitor.
AT commands are used to connect:
2022-02-23T07:48:23.978Z DEBUG modem >> AT
2022-02-23T07:48:23.990Z DEBUG modem << OK
2022-02-23T07:48:24.697Z DEBUG modem >> AT+CFUN?
2022-02-23T07:48:24.712Z DEBUG modem << +CFUN: 0
2022-02-23T07:48:24.724Z DEBUG modem << OK
2022-02-23T07:48:28.448Z INFO Updating CA certificate...
2022-02-23T07:48:28.452Z DEBUG modem >> AT%CMNG=0,757,0,"-----BEGIN CERTIFICATE-----
2022-02-23T07:48:28.607Z DEBUG modem >> -----END CERTIFICATE-----"
2022-02-23T07:48:28.808Z DEBUG modem << OK
2022-02-23T07:48:28.810Z INFO Updating client certificate...
2022-02-23T07:48:28.813Z DEBUG modem >> AT%CMNG=0,757,1,"-----BEGIN CERTIFICATE-----
2022-02-23T07:48:29.026Z DEBUG modem >> -----END CERTIFICATE-----"
2022-02-23T07:48:29.465Z DEBUG modem << OK
2022-02-23T07:48:29.467Z INFO Updating private key...
2022-02-23T07:48:29.468Z DEBUG modem >> AT%CMNG=0,757,2,"-----BEGIN EC PARAMETERS-----
2022-02-23T07:48:29.480Z DEBUG modem >> BggqhkjOPQMBBw==
2022-02-23T07:48:29.493Z DEBUG modem >> -----END EC PARAMETERS-----
2022-02-23T07:48:29.507Z DEBUG modem >> -----BEGIN EC PRIVATE KEY-----
2022-02-23T07:48:29.558Z DEBUG modem >> -----END EC PRIVATE KEY-----"
2022-02-23T07:48:31.051Z DEBUG modem << OK
2022-02-23T07:48:31.052Z INFO Certificate update completed
2022-02-23T07:49:14.233Z DEBUG modem >> AT+CFUN?
2022-02-23T07:49:14.246Z DEBUG modem << +CFUN: 0
2022-02-23T07:49:14.266Z DEBUG modem << OK
2022-02-23T07:49:21.325Z DEBUG modem >> AT+CEREG=5
2022-02-23T07:49:21.337Z DEBUG modem << OK
2022-02-23T07:49:25.810Z DEBUG modem >> AT+CFUN=1
2022-02-23T07:49:25.852Z DEBUG modem << OK
2022-02-23T07:49:27.750Z DEBUG modem << +CEREG: 2,"026F","00332521",7
2022-02-23T07:49:29.448Z DEBUG modem << +CEREG: 5,"026F","00332521",7,,,"00011110","11100000"
2022-02-23T07:50:30.354Z DEBUG modem >> AT#XMQTTCON=1,"test_name","","","test_name.amazonaws.com",8883,757
2022-02-23T08:26:50.994Z DEBUG modem << ERROR
However, when using "RSA PRIVATE KEY" there are no problems, the broker responds, the ping passes correctly.
2022-02-22T16:14:46.286Z ERROR Error: 'AT#XMQTTCON=1,"test_name","","","test_name.amazonaws.com",8883,321
2022-02-22T16:14:52.756Z DEBUG modem << OK
2022-02-22T16:14:53.108Z DEBUG modem << #XMQTTEVT: 0,0
2022-02-22T16:15:10.692Z DEBUG modem << +CEREG: 5,"026F","00332521",7,,,"00011110","11100000"
2022-02-22T16:15:53.542Z DEBUG modem << #XMQTTEVT: 9,0
2022-02-22T16:16:53.257Z DEBUG modem << #XMQTTEVT: 9,0
    Can it be due to an issue with certificate size? From the modem FW 1.3.1 release notes:
    • - TLS/DTLS
      • Up to three simultaneous TLS/DTLS connections are possible.
      • Maximum server certificate chain size has a limit of 4kB.
      • Server certificate expiry time is not verified.
      • pkcs#8 is not supported.
      • Absolute maximum number of supported credentials is 32. The actual amount depends on size of credentials as memory area reserved for credentials may be a limiting factor as well.
      • DTLS supports PSK authentication only.
      • 2kB secure socket buffer size.
    Are you trying to connect to Amazon AWS? If so, please follow the steps provided in our AWS IoT documentation in regards to certificates.
    Øyvind
