Implementing 'Developing Bluetooth Low Energy products using nRF Connect' video on nRF5340-DK
I am working from this video:
https://webinars.nordicsemi.com/developing-bluetooth-low-energy-6
Which nRF5340-DK build configuration should I use please?
  • nrff5340dk_nrf5340_cpuapp
  • nrff5340dk_nrf5340_cpuapp_ns
  • nrff5340dk_nrf5340_cpunet
I've downloaded the source files and manually put the folders named 'bluetooth_remote' and 'bluetooth_remote_template' in my macOS workspace folder.
I add the 'bluetooth_remote_template' folder as a new application into VS Code, immediately I'm asked if I want to change from the current v1.9.0 version of the nRF Connect SDK. I assume that I should be working with the latest version, so confirm that I don't want to change. When I then open the project in Explorer and look at main.c I see the following Includes underlined with red squiggles.
main.c
#include <zephyr.h>
#include <logging/log.h>
#include <dk_buttons_and_leds.h>
#include "remote.h"
The same is true for the Includes in remote.c and remote.h:
remote.c
#include "remote.h"
remote.h
#include <zephyr.h>
What do I need to do to provide the paths to these header files please?
  • Hi
    alwalker said:
    however when I launch VS Code with the nRF Connect SDK v1.9.1 in Toolchain Manager I still need to manually change the toolchain etc. to v1.9.1 as it is not set automatically. It would be good if this was set as specified by the selection made in Toolchain Manager.
    The Toolchain Manager does not set the version in VS Code, that is correct.
    But is it the same as the previous time you used VS Code?
    alwalker said:
    Is there any news on a fix or workaround for this error please?
    boards/arm/nrf5340dk_nrf5340/Kconfig.defconfig:62: error: couldn't parse 'default $(dt_chosen_reg_size_hex,$(DT_CHOSEN_Z_CODE_PARTITION))': macro expanded to blank string
    No, there is not yet any fix for this as far as I know.
    For a workaround, you could have a look at the file mentioned and see if you can change something here I guess.
    alwalker said:
    Are the other two C syntax errors something that would be fixed by code from the snippets.c file please?
    too few arguments in invocation of macro "Z_FOR_LOOP_1"
    Are you logging as explained in the Logging documentation?
    Is the logging error still apparent after you build the project?
    Sigurd Hellesvik
