sd_flash_* operations no longer working after SDK(14.2) -> (15.2) and SD(5.1) -> (6.1.1) migration
Hi there,
I'm in the midst of migrating between SDK14.2->15.2, and SD 5.1->6.1
I'm calling sd_flash_write() and sd_flash_page_erase() before enabling the SoftDevice with no issue, however, once I enable the softdevice these functions return NRF_ERROR_BUSY indefinitely. This happens even though I have not started advertising. I have tried calling it 10,000 times with a delay of 1ms between tries, and still always get NRF_ERROR_BUSY.
I would prefer to use the SoftDevice directly (as opposed to Fstorage) to leverage it's async properties.
Do you know why this method used to work where now it does not?
Attached is my sdk_config.h if that helps
Matthew
    Do the first call to sd_flash_write()/sd_flash_page_erase() after enabling the softdevice return successfully?
    Are you processing the events from the softdevice? E.g through the Softdevice handler library, etc?
    Are you calling the functions from main context or interrupt context? Can you post a minimal code showing how we can reproduce this problem?
    Fstorage is also using the sd_flash* API in its Softdevice backend. It is not possible to write/erase the flash through NVMC peripheral when the softdevice is enabled, without using the Softdevice APIs.
    Jørgen
  • Hi Jorgen,
    I think I have identified part of the issue.
    I can call many successful sd_flash* operations before enabling the SD, but but after I enable the SD, it always returns busy. However, if I do not call an sd_flash* function before enabling the SD, sd_flash* invocations return NRF_SUCCESS the first time, and NRF_BUSY thereafter.
    (I am using the Softdevice handler library by calling nrf_sdh_enable_request(), though I am not registering an nrf_soc observer.)
    Example:
      ret_code_t err_code = (ret_code_t)NRF_SUCCESS;
      // Initialize the SoftDevice handler module.
      err_code = (ret_code_t)nrf_sdh_enable_request();//returns NRF_SUCCESS
      uint8_t const conn_cfg_tag = 1;
      uint32_t ram_start = 0;
      err_code = (ret_code_t)nrf_sdh_ble_default_cfg_set(conn_cfg_tag, &ram_start);
      // enable SoftDevice
      err_code = (ret_code_t)sd_ble_enable(&ram_start);
      err_code = sd_flash_page_erase(0x76);// returns NRF_SUCCESS
      rf_delay_ms(90); //flash operation takes maximum of 90ms
      err_code = sd_flash_page_erase(0x76);// returns NRF_BUSY
    Example 2:
    I'm calling these functions in the main context.
    In regards to fstorage, it's my understanding that nrf_fstorage_write() enqueues a flash write operation onto the application event queue (which is eventually serviced through a call to app_sched_execute()), whereas sd_flash* directly kicks of a flash operation (blocking if SD enabled, async if not). Is this correct?
    Thanks
  • in my last paragraph, I meant to say *async if SD enabled, blocking if not*
    I tried adding your code examples to the ble_app_beacon example in nRF5 SDK v15.2.0, by replacing the ble_stack_init function and removing the advertising parts. With this configuration, I'm not getting the NRF_ERROR_BUSY return code from the second call to sd_flash_page_erase(). This leads me to believe there is something else in your application causing this behavior. Attaching the example project for reference: ble_app_sd_flash_sdk15.2.0_s132_v6.1.1.zip
    Fstorage does not use the application scheduler library. It has its own queue implementation, which enables you to schedule multiple flash operations from the application, without having to wait for the Softdevice to complete the previous operation, but it does not depend on the application to execute the scheduled operations. When you call the fstorage write or erase functions, the operation is added to the queue, but the function will immediately call the queue_start() function to start processing the queued operations. When a flash operation is completed, fstorage library will be notified by the Softdevice flash event, and fstorage will start the next queued flash operation.
    The softdevice will accept a requested flash operation, but it will schedule the execution between other BLE activity. See Flash memory API and Scheduling. This implies that it is not safe to use a delay set to the maximum time for the flash operation according to the product specification, you need to wait for the NRF_EVT_FLASH_OPERATION_SUCCESS/NRF_EVT_FLASH_OPERATION_ERROR events before starting a new operation.
    Jørgen
  • Thanks for you detailed response,
    Other than a configuration issue in sdk_config.h, I don't know how my application could be causing this behavior. I made a test main() which only runs the code snippets I shared, so nothing else is happening. Are there any relevant configuration macros in sdk_config.h that could be causing this?
    I also went ahead and tried registering a SDH_SOC observer to print some output when the FLASH_OPERATION_* event is generated, but it never runs.
    void soc_handler(uint32_t evt_id, void * p_context)
    //This never prints, soc_handler never called?
      UART_CRITICAL_PRINTF("soc_handler evt_id:%d", evt_id);
    NRF_SDH_SOC_OBSERVER(obs, 1, soc_handler, NULL);
    It seems like the FLASH_OPERATION event is never being generated so the SD always believes it's busy, returning the error that I'm seeing.
    Thanks
