I have a project (using NUS) that comes in 2 parts:
- NRF52840 (peripheral) which generate advertising when they have information to transmit.
- PCA10059 USB dongles that constantly scan for the above peripherals
I encounter a problem when several USB dongles (with same firmware) receive advertising from a device...
In this case, sometimes the dongles synchronize perfectly and simultaneously try to communicate with the peripheral which launched its advertising.
Each dongle then generates a BLE_NUS_C_EVT_DISCONNECTED event with which I relaunch a scan_start, and so on a few times for ten seconds !
I tried to modify NRF_BLE_SCAN_SCAN_INTERVAL and NRF_BLE_SCAN_SUPERVISION_TIMEOUT like this (but with some small result) :
// <o> NRF_BLE_SCAN_SCAN_INTERVAL - Scanning interval. Determines the scan interval in units of 0.625 millisecond.
#ifndef NRF_BLE_SCAN_SCAN_INTERVAL
#define NRF_BLE_SCAN_SCAN_INTERVAL 100
// <o> NRF_BLE_SCAN_SCAN_DURATION - Duration of a scanning session in units of 10 ms. Range: 0x0001 - 0xFFFF (10 ms to 10.9225 ms). If set to 0x0000, the scanning continues until it is explicitly disabled.
#ifndef NRF_BLE_SCAN_SCAN_DURATION
#define NRF_BLE_SCAN_SCAN_DURATION 0
// <o> NRF_BLE_SCAN_SCAN_WINDOW - Scanning window. Determines the scanning window in units of 0.625 millisecond.
#ifndef NRF_BLE_SCAN_SCAN_WINDOW
#define NRF_BLE_SCAN_SCAN_WINDOW 100
// <o> NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL - Determines minimum connection interval in milliseconds.
#ifndef NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL
#define NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL 7.5
// <o> NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL - Determines maximum connection interval in milliseconds.
#ifndef NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL
#define NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL 40
// <o> NRF_BLE_SCAN_SLAVE_LATENCY - Determines the slave latency in counts of connection events.
#ifndef NRF_BLE_SCAN_SLAVE_LATENCY
#define NRF_BLE_SCAN_SLAVE_LATENCY 4
// <o> NRF_BLE_SCAN_SUPERVISION_TIMEOUT - Determines the supervision time-out in units of 10 millisecond.
#ifndef NRF_BLE_SCAN_SUPERVISION_TIMEOUT
#define NRF_BLE_SCAN_SUPERVISION_TIMEOUT 800
static ble_gap_scan_params_t m_scan_param =
.active = 1,
.interval = NRF_BLE_SCAN_SCAN_INTERVAL,
.window = NRF_BLE_SCAN_SCAN_WINDOW,
.timeout = NRF_BLE_SCAN_SCAN_DURATION,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
.scan_phys = BLE_GAP_PHY_1MBPS,
static ble_gap_conn_params_t m_conn_param =
.min_conn_interval = (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL, UNIT_1_25_MS),
.max_conn_interval = (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL, UNIT_1_25_MS),
.slave_latency = (uint16_t)NRF_BLE_SCAN_SLAVE_LATENCY,
.conn_sup_timeout = (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_SUPERVISION_TIMEOUT, UNIT_10_MS),
static void scan_init(void)
ret_code_t err_code;
nrf_ble_scan_init_t init_scan;
m_scan_param.interval = NRF_BLE_SCAN_SCAN_INTERVAL + (NRF_FICR->DEVICEADDR[0] & 0xFF);
m_scan_param.window = m_scan_param.interval;
m_conn_param.conn_sup_timeout = (uint16_t)MSEC_TO_UNITS(NRF_BLE_SCAN_SUPERVISION_TIMEOUT + (NRF_FICR->DEVICEADDR[0] & 0xFF)*10, UNIT_10_MS);
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
init_scan.p_scan_param = &m_scan_param;
init_scan.p_conn_param = &m_conn_param;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
In this page Connecting to advertisers performing extended advertising, I think I'm in the variant #4 but I never get the timeout event...
What's the best pratice for this case ?
Gaétan
Related post:
- https://devzone.nordicsemi.com/f/nordic-q-a/67580/two-centrals-both-scanning/
- https://devzone.nordicsemi.com/f/nordic-q-a/49112/issue-with-2-centrals-and-single-peripheral/
