SAADC VDD Measurement with nRF52833
Hello, I am trying to measure the input voltage on an nRF52833 and it is not behaving as expected.
The following code is taken from here and works as expected on any nRF52832-based device I have tested, returning the correct board input voltage. When I try it on our nRF52833 board it returns 0.
Are there any changes to the SAADC configuration or register addresses that need to be accounted for when porting between the 832 and 833? Thank you in advance.
#include "nrf52833.h"
#include "nrf52833_bitfields.h"
uint16_t battery_sample_voltage()
    volatile int16_t result = 0;
    volatile float precise_result = 0;
    // Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain.
    NRF_SAADC->CH[0].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6    << SAADC_CH_CONFIG_GAIN_Pos) |
                            (SAADC_CH_CONFIG_MODE_SE         << SAADC_CH_CONFIG_MODE_Pos) |
                            (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
                            (SAADC_CH_CONFIG_RESN_Bypass     << SAADC_CH_CONFIG_RESN_Pos) |
                            (SAADC_CH_CONFIG_RESP_Bypass     << SAADC_CH_CONFIG_RESP_Pos) |
                            (SAADC_CH_CONFIG_TACQ_3us        << SAADC_CH_CONFIG_TACQ_Pos);
    // Configure the SAADC channel with VDD as positive input, no negative input(single ended).
    NRF_SAADC->CH[0].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
    NRF_SAADC->CH[0].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
    // Configure the SAADC resolution.
    NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
    // Configure result to be put in RAM at the location of "result" variable.
    NRF_SAADC->RESULT.MAXCNT = 1;
    NRF_SAADC->RESULT.PTR = (uint32_t)&result;
    // No automatic sampling, will trigger with TASKS_SAMPLE.
    NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
    // Enable SAADC (would capture analog pins if they were used in CH[0].PSELP)
    NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
    // Calibrate the SAADC (only needs to be done once in a while)
    NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
    while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0);
    NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
    while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy <<SAADC_STATUS_STATUS_Pos));
    // Start the SAADC and wait for the started event.
    NRF_SAADC->TASKS_START = 1;
    while (NRF_SAADC->EVENTS_STARTED == 0);
    NRF_SAADC->EVENTS_STARTED = 0;
    // Do a SAADC sample, will put the result in the configured RAM buffer.
    NRF_SAADC->TASKS_SAMPLE = 1;
    while (NRF_SAADC->EVENTS_END == 0);
    NRF_SAADC->EVENTS_END = 0;
    // Convert the result to voltage
    // Result = [V(p) - V(n)] * GAIN/REFERENCE * 2^(RESOLUTION)
    // Result = (VDD - 0) * ((1/6) / 0.6) * 2^14
    // VDD = Result / 4551.1
    precise_result = (float)result / 4551.1f;
    // Stop the SAADC, since it's not used anymore.
    NRF_SAADC->TASKS_STOP = 1;
    while (NRF_SAADC->EVENTS_STOPPED == 0);
    NRF_SAADC->EVENTS_STOPPED = 0;
    return (uint16_t)(precise_result*1000);
  • I think the issue is that on the nRF52833, the network stack is using a different SAADC channel to perform voltage measurement (Wirepas closed-source stack).
    When I use SAADC channel 1 instead of channel 0 on the nRF52833, the code works as expected.
    To test the theory I un-set the PSELP register on all channels to disable them before calling the above function.
    Per the documentation: An analog input is selected as a positive converter input if CH[n].PSELP is set, setting CH[n].PSELP also enables the particular channel.
    for(uint8_t i=0; i<8; i++)
        NRF_SAADC->CH[i].PSELP = 0;
    But still, it only works on channel 1. Is there something else that needs to be done to load the register configuration?
    I tested the above code in a standalone application on a nRF52833 DK, and it seems to be working as expected.
    Did you test it on your end, without initializing the "network stack"? If it works without the stack, you should contact the developers of the stack to get help regarding how they use the SAADC peripheral.
    You may also test the workaround from Errata 212, which will reset the whole SAADC peripheral, but I'm not sure how well the network stack will react if you mess with its configuration.
    Jørgen
  • Thanks Jorgen, I tested this out before the network stack was initialized and the peripheral works as expected. The ticket can be closed.
