Error when building configuration
When building a project with nrfonnect , sdk-nrf v1.7.1 that worked for colleagues I got strange warnings:
and the building aborts.
What is very strange is that some of the files where error are reported do not exist on my file system:
  1. /media/manu/manuLinux/code/sources.yguel/straTagGem/stratg/nordic_nrf/nrf9160/custom_serial_lte_modem/build/modules/hal_nordic/nrfx/Kconfig
  2. /media/manu/manuLinux/code/sources.yguel/straTagGem/stratg/nordic_nrf/nrf9160/custom_serial_lte_modem/build/drivers/clock_control/Kconfig.nrf
  3. /media/manu/manuLinux/code/sources.yguel/straTagGem/stratg/nordic_nrf/nrf9160/custom_serial_lte_modem/build/soc/arm/nordic_nrf/nrf91/Kconfig.series
A lot of things are missing in the build directory that the building is trying to use (/media/manu/manuLinux/code/sources.yguel/straTagGem/stratg/nordic_nrf/nrf9160/custom_serial_lte_modem/build)
  • modules/hal_nordic
  • drivers
  • soc
I also get CMake warning about old behaviors but I do not know if this is related
It correspond tot that policy:
# Use the old CMake behaviour until the build scripts have been ported
# to the new behaviour.
# CMP0079: "target_link_libraries() allows use with targets in other directories"
cmake_policy(SET CMP0079 OLD)
So maybe the problem is related to that ?
    Try to delete the build folder and build again.
    Are you building the sample (which one) or your application?
    Are you using nRF9160DK or a custom board?
    Amanda
  • I try to delete the build folder and build again (it does not solve the problem).
    I was trying to build our own application.
    We are using the nRF9160DK.
  • Hi Amanda,
    I tried a Hello_world sample project and get the exact same error:
    I also check and the building system is also looking for non existent folders:
    • in build/modules directory there is only a nrf repository (no hal_nordic directory)
    • soc/arm/nordic_nrf/nrf91/Kconfig.series does not exist (directory build/soc does not exist)
  • Try this command "west build -p -b nrf9160dk_nrf9160_ns". If it still has the issue, try to run "west update" and do it again.
    -Amanda
    It does not change anything. The warnings causing the error are still there and still cause the error.
    Furthermore, the missing folders are still missing.
    - Regards,
    Manuel
1 2
