nRF9160 lwm2m_client Error starting process C:\ncs\v1.9.0\toolchain\opt\bin\arm-none-eabi-gcc.exe
I'm trying to build the lwm2m_client using SES through the toolchain manager.  I continue to get the following error:  "Error starting process C:\ncs\v1.9.0\toolchain\opt\bin\arm-none-eabi-gcc.exe"  I'm using SDK v1.9.0 and SES V5.68 on a windows 10 machine.  I have verified arm-none-eabi-gcc.exe is in the directory.
    In the drop down meny, where you have currently showing "tasks" - could you change this to "output" and paste the full build log?
    Håkon
  • Building ‘cmake_object_order_depends_target_mbedcrypto_base’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mbedcrypto’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-mkdir’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-download’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-update’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-patch’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-configure’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build’
    1> ninja: no work to do.
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-install’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/CMakeFiles/spm_subimage-complete’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/CMakeFiles/spm_subimage’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-done’ from solution ‘build’ in configuration ‘Common’
    Building ‘spm/zephyr/zephyr.hex’ from solution ‘build’ in configuration ‘Common’
    Building ‘spm/zephyr/zephyr.elf’ from solution ‘build’ in configuration ‘Common’
    Building ‘spm/libspmsecureentries.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrf/samples/spm_subimage’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.9.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.9.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.9.0/zephyr/include/dt-bindings/pinctrl/nrf-pinctrl.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
    Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/ncs/v1.9.0/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__drivers__gps__nrf9160_gps’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__drivers__sensor__sensor_sim’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__at_cmd_parser’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__at_monitor’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__date_time’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__dk_buttons_and_leds’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__lte_link_control’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__modem_info’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__modem_key_mgmt’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__nrf_modem_lib’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__lib__wave_gen’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__modules__cddl-gen’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__subsys__dfu__dfu_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__subsys__dfu__fmfu_fdev’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__subsys__fw_info’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__subsys__net__lib__download_client’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__subsys__net__lib__fota_download’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_..__nrf__subsys__net__lib__lwm2m_client_utils’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__cmse’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__arm__core__aarch32__mpu’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_isr_tables’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_arch__common’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_boards__arm__nrf9160dk_nrf9160’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__clock_control’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__console’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__entropy’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__flash’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__gpio’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__i2c’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__sensor’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__spi’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_drivers__timer’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_lib__libc__newlib’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mbedtls_zephyr’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_mcuboot_util’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_modules__hal_nordic__nrfx’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_soc__arm__common__cortex_m’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__dfu__boot’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__net’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__net__ip’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__net__lib__http’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__net__lib__lwm2m’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_subsys__random’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/autoconf.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/linker_zephyr_pre0.cmd’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/linker_zephyr_pre0.cmd’
    1> Error starting process C:\ncs\v1.9.0\toolchain\opt\bin\arm-none-eabi-gcc.exe
    Build failed
    Thank you for reporting this to us. I have been able to recreate this locally, and reported this issue back to the developers.
    The issue seems to be present in only in SES-NE, so the good news is that you can work around this issue by for instance using VS Code instead.
    Håkon
