Softdevice - basic BLE advertising/transmission. Getting return error code 18 for ble_advertising_start() function
I am using the nRF 52840 DK board. Using nRF5_SDK_17.0.2 I am trying to implement basic BLE advertising in my code. Also, I have turned on the RTT log. From the log, I can see I am getting error code 18 for the ble_advertising_start() function (as per forum discussion here, error code 18 is the NRF_ERROR_CONN_COUNT error, which could indicate that you are trying to start advertising while the previous connection is not properly closed. ). But in my code, I am not trying to start advertising again and again. Just starting once after boot. Can anyone help me why I am getting error code 18 here?
I am attaching my sdk_config.h file below:
1346.sdk_config.h
Also attaching code file.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "bsp_btn_ble.h"
#include "ble_conn_state.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                     "Hello"                       /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    ret_code_t              err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
NRF_LOG_INFO("sd_ble_gap_device_name_set %d",err_code);
       /*err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
       APP_ERROR_CHECK(err_code); */
NRF_LOG_INFO("sd_ble_gap_ppcp_set %d",err_code);
 NRF_LOG_INFO("gap_params_init done.");
 switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
             NRF_LOG_INFO("INSIDE BLE_ADV_EVT_FAST");
        case BLE_ADV_EVT_IDLE:
           // sleep_mode_enter();
      uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
         NRF_LOG_INFO("nrf_sdh_enable_request %d",err_code);
    uint32_t ram_start = 0;
     NRF_LOG_INFO("nrf_sdh_ble_default_cfg_set %d",err_code);
    // Enable BLE stack.
     NRF_LOG_INFO("nrf_sdh_ble_enable %d",err_code);
     NRF_LOG_INFO("ble_stack_init done.");
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
     NRF_LOG_INFO("ble_advertising_init %d",err_code);
    NRF_LOG_INFO("advertising_init done.");
static void log_init(void)
    ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
  NRF_LOG_INFO("ble_advertising_start %d",err_code);
     NRF_LOG_INFO("advertising_start done.");
    // Initialize.
    log_init();
    ble_stack_init();
    gap_params_init();
advertising_init();
advertising_start();
    NRF_LOG_INFO("Ble tutorial started.");
while (true)//this is need to print.
        NRF_LOG_FLUSH();
        __SEV();
        __WFE();
        __WFE();
        // no implementation needed
I am able to build the code but BLE is not getting advertised.
Output in the debug terminal is as shown below:
<info> app: nrf_sdh_enable_request 0
<info> app: nrf_sdh_ble_default_cfg_set 0
<info> app: nrf_sdh_ble_enable 0
<info> app: ble_stack_init done.
<info> app: sd_ble_gap_device_name_set 0
<info> app: sd_ble_gap_ppcp_set 0
<info> app: gap_params_init done.
<info> app: ble_advertising_init 0
<info> app: advertising_init done.
<info> app: ble_advertising_start 18
<info> app: advertising_start done.
<info> app: Ble tutorial started.
In the above debug terminal ble_advertising_start should be 0.
I am attaching the screenshot for your reference.
Am I doing anything wrong? Also, I am attaching a zip file of the code base.
iotians_device_loadcell.zip
Please help.
Thanks and regards,
Neeraj Dhekale
