VS studio not building samples
Goodday
I thought I would try the webinar
Desktop️ nRF Connect for VS Code Webinar - Hackster.io
Im getting the following error after I add Build configuration
Building hid3534
west build --build-dir e:\aacrs\02_12\nordic\vs_remote_tutorial\hid\hid3534\build e:\aacrs\02_12\nordic\vs_remote_tutorial\hid\hid3534 --pristine --board nrf52840dk_nrf52840 -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE"
usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
west: error: argument <command>: invalid choice: 'build' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate')
The terminal process terminated with exit code: 2.
I have uninstalled and reinstalled both vs code and nRf connect..
My connected 52840 DK does show up in connected devices.
    Can you please provide the output from running the following from the VS code command pallette:
    Have you verified that the toolchain path is correct
    Øyvind
  • hi Oyvind
    yes tool chain path is correct
    General support info below
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19043",
        "vscode": "1.64.2",
        "electron": "13.5.2",
        "node": "v14.16.0"
      "system": {
        "date": "2022-02-28T10:13:32.043Z",
        "vscodeRoot": "c:\\Users\\meltb\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:01:02",
        "osUptime": "02:18:37",
        "cpu": {
          "model": "Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz",
          "speed": "1800 MHz",
          "count": 4
        "memory": {
          "total": "7.89 GB",
          "free": "1.74 GB"
      "workspace": {
        "name": "Untitled (Workspace)",
        "workspaceFile": "1646035652424",
        "folders": [
          "e:\\aacrs\\02_12\\nordic\\vs_remote_tutorial\\test\\hello_world"
      "extensions": {
        "internal": {
            "version": "2022.1.192",
            "path": "c:\\Users\\meltb\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.1.192",
            "isActive": true
            "version": "2022.1.30",
            "path": "c:\\Users\\meltb\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.1.30",
            "isActive": true
          "nordic-semiconductor.devicetree": null,
          "nordic-semiconductor.kconfig": null
        "external": {
          "marus25.cortex-debug": "1.2.2",
          "ms-vscode.cpptools": "1.8.4",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.12",
          "ms-vscode.js-debug": "1.64.3",
          "ms-vscode.js-debug-companion": "1.0.15",
          "ms-vscode.references-view": "0.0.81",
          "ms-vscode.vscode-js-profile-table": "0.0.18",
          "cschlosser.doxdocgen": "1.4.0",
          "jeff-hykin.better-cpp-syntax": "1.15.13",
          "ms-vscode-remote.remote-containers": "0.217.4",
          "ms-vscode-remote.remote-ssh": "0.74.0",
          "ms-vscode-remote.remote-ssh-edit": "0.74.0",
          "ms-vscode-remote.remote-wsl": "0.64.2",
          "ms-vscode.cmake-tools": "1.9.2",
          "ms-vscode.cpptools-extension-pack": "1.1.0",
          "ms-vscode.cpptools-themes": "1.0.0",
          "twxs.cmake": "0.0.17"
      "tools": {
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.58b",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.3",
        "cmake": "Not found",
        "west": "Not found",
        "C:\\Users\\meltb\\AppData\\Local\\Microsoft\\WindowsApps\\python.exe": null,
        "ninja": "Not found",
        "gperf": "Not found",
        "dtc": "Not found",
        "gnuarmemb": "Not found",
        "gn": "Not found",
        "C:\\Program Files\\Git\\cmd\\git.exe": "2.27.0.windows.1"
      "connectedDevices": [
          "id": "683015900"
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [],
          "jlink": {
            "rtosPlugin": ""
          "kconfig": {
            "interface": "kconfig"
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "enableTelemetry": false
          "terminalMode": "character"
        "nordic-semiconductor.devicetree": {
          "modules": [
            "${zephyrBase}",
            "${zephyrBase}/../nrf",
          "zephyr": "",
          "ctxFile": "",
          "defaultBoard": ""
        "nordic-semiconductor.kconfig": {
          "root": "",
          "env": {},
          "cfiles": true,
          "disable": false,
          "zephyr": {
            "base": ""
          "python": "",
          "liveValue": true
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "flattenAnonymous": false,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\meltb",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\meltb"
      "terminal": {
        "shell": null,
        "defaultProfile": null
  • Thanks for providing this information. From the output I can see that the path is not configured correctly in VS Code.
    To what path did you install the nRF Connect SDK (NCS) to? Have you installed NCS using the Toolchain Manager?
    Thanks.
    -Øyvind
  • Yes I used nRF connect which installed it to the default \ncs folder under \user directory. My actual nordic SDK and softdevices  lies on a different drive E:\aacrs\02_12\nordic\SDK\nRF5_SDK_17.1.0. this is also the drive I use for Segger.
    I keep  my custom projects within the \example folder of   \nrf_SDK17.1
  • Please note that nRF Connect SDK is not the same as nRF5 SDK.
    The VS Code extension only supports the nRF Connect SDK.
