SPIM on nRF52832 and nRF52810
I have enabled SPIM on nRF52810 and worked normally.But when I enabled on nRF52832, it worked unusual.
I had defined CONFIG_NFCT_PINS_AS_GPIOS because used P0.9 and P10. Is there any other settings different between nRF52810 and nRF52832?
  • Do not use the NFC pins with any other peripheral interface such as uart, i2c, spi,...  I can use it to flip on/off no problem.
    Can you try to reduce the SPIM speed to see if that impact the issue? Do you have a logic analyzer trace to look at for comparison?
    Kenneth
  • We had this intermittent issue when using NFC pins as gpio a couple of years ago.  This happened at any speed.  It was very hard to find.
  • TWI (SPI not tested) works for us: using CONFIG_NFCT_PINS_AS_GPIOS and nRF52832 2. rev and P0.2/SCL, P0.9/SDA @100kHz/400kHz.
    Should we expect any troubles?
  • I need to correct my problem.
    I have defined SPI GPIO:
    SCK: P0.4
    MISO: P0.5
    MOSI: P0.6
    SS: P0.7
    And the SPI sensor need another IO write or read to read/write data.
    RST:P0.8
    BUSY: P0.9
    DIO1: P0.10
    Here is my GPIO configration:
    #define SPI_SCK_PIN    4
    #define SPI_MISO_PIN   5
    #define SPI_MOSI_PIN   6
    #define SPI_SS_PIN     7
    #define RADIO_nRESET_PIN  8
    #define RADIO_BUSY_PIN    9
    #define RADIO_DIO1_PIN    10
    nrf_gpio_cfg_input(RADIO_DIO1_PIN, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_input(RADIO_BUSY_PIN, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_output(RADIO_nRESET_PIN);
    nrf_gpio_pin_set(RADIO_nRESET_PIN);
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    //  spi_config.ss_pin   = NRF_DRV_SPI_PIN_NOT_USED;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
    //	spi_config.frequency = SPI_FREQUENCY_FREQUENCY_K250;
    //	spi_config.irq_priority = 4;
    	nrf_gpio_cfg_output(SPI_SS_PIN);
        nrf_gpio_pin_set(SPI_SS_PIN);
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    When the application worked on nRF52832 custom board, the SPI will read wrong data, I'll show you logic analyzer trace
    latter.
    Is the NFC pin occur uncertainly voltage even  I defined CONFIG_NFCT_PINS_AS_GPIOS?
    I'll upload the software or hardware if you need.
     Logic analyzer trace:
    My application code:
    nrf_delay_ms(500);
    uint8_t SpiInOut( uint8_t txBuffer)
    		uint8_t m_rx=0;
    		uint32_t timeout = 10000;
    		spi_xfer_done = false;
    		APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &txBuffer, 1, &m_rx, 1));
    		while (!spi_xfer_done)
    				__WFE();
    		NRF_LOG_INFO("SPI RX:%02x  TX:%02x",m_rx,txBuffer);
    		return m_rx;
    void SpiIn( uint8_t *txBuffer, uint16_t size )
    		uint8_t m_rx_buff[255]={0};
    		APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, txBuffer, size, m_rx_buff,NULL));
    				__WFE();
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
    void m_spi_lora_init(void)
    		nrf_delay_ms(100);
    //		m_lora_init(LORA_INIT_MODE);
    		m_lora_check();
    		NRF_LOG_INFO("LORA initialized.");
    void m_lora_check(void)
    		uint8_t data[2]={0x12,0x34};
        uint8_t test[2]={0,0};
    		while(1)
        Radio.WriteBuffer(0x06C0,data,2);
        Radio.ReadBuffer(0x06C0,test,2);
    		if((test[0]==data[0])&&(test[1]==data[1]))
    				NRF_LOG_INFO("Lora SUCCESS");
    				m_tag_type.check[TAG_LORA]  = TAG_CHECK_SUCCESS;
    		}else
    				NRF_LOG_INFO("Lora FAIL %02x %02x",test[0],test[1]);
    				m_tag_type.check[TAG_LORA] = TAG_CHECK_ERROR;
    		nrf_delay_ms(1000);
    		NRF_LOG_FLUSH();
    const struct Radio_s Radio =
        RadioInit,
        RadioGetStatus,
        RadioSetModem,
        RadioSetChannel,
        RadioIsChannelFree,
        RadioRandom,
        RadioSetRxConfig,
        RadioSetTxConfig,
        RadioCheckRfFrequency,
        RadioTimeOnAir,
        RadioSend,
        RadioSleep,
        RadioStandby,
        RadioRx,
        RadioStartCad,
        RadioSetTxContinuousWave,
        RadioRssi,
        RadioWrite,
        RadioRead,
        RadioWriteBuffer,
        RadioReadBuffer,
        RadioSetMaxPayloadLength,
        RadioSetPublicNetwork,
        RadioGetWakeupTime,
        RadioIrqProcess,
        // Available on SX126x only
        RadioRxBoosted,
        RadioSetRxDutyCycle
    void RadioWriteBuffer( uint16_t addr, uint8_t *buffer, uint8_t size )
        SX126xWriteRegisters( addr, buffer, size );
    void SX126xWriteRegisters( uint16_t address, uint8_t *buffer, uint16_t size )
        SX126xCheckDeviceReady( );
        nrf_gpio_pin_clear(SPI_SS_PIN);
        SpiInOut(RADIO_WRITE_REGISTER );
        SpiInOut(( address & 0xFF00 ) >> 8 );
        SpiInOut( address & 0x00FF );
        for( uint16_t i = 0; i < size; i++ )
            SpiInOut(buffer[i] );
        SX126xWaitOnBusy( );
    void RadioReadBuffer( uint16_t addr, uint8_t *buffer, uint8_t size )
        SX126xReadRegisters( addr, buffer, size );
    void SX126xReadRegisters( uint16_t address, uint8_t *buffer, uint16_t size )
        SpiInOut(RADIO_READ_REGISTER );
        SpiInOut( 0 );
            buffer[i] = SpiInOut(0 );
