How to recover a nRF9160 from sporadic ENETDOWN
Using a Thingy!91 (v1.0.0 and v1.4.0, firmware 1.2.3, 1.2.7) I get sometimes (every couple of days) a ENETDOWN when sending data out. Before that ENETDOWN, the device was usually able to exchange 100 and more UDP messages.
Currently I do a "sys_reboot(SYS_REBOOT_COLD)", but I'm wondering, if there are less massive ways to recover.
I found other questions, but I'm still struggling to see an "useful" answer. e.g.
https://devzone.nordicsemi.com/f/nordic-q-a/57642/nrf9160-lte-modem-documentation
but the link at the end, ends in "NOT FOUND".
So, what is the recommended way to recover from ENETDOWN?
  • Hello Achim,
    As Håkon described in the above mentioned case, our recommendation is to subscribe to unsolicited result codes of +CEREG and use +CESQ, or subscribe to %CESQ. This way, you can verify that ENETDOWN actually occurs due to that the modem has lost connection to the network.
    Putting the modem into flight mode for a while with AT+CFUN=4 could be a good thing to do in such a situation, but it of course depends a little on your use case and the connection/network status as well.
    Markus
  • Hello Markus
    I already use
    lte_lc_connect_async(lte_handler);
    so, which events should be used for verification? Currently I use
    LTE_LC_EVT_RRC_UPDATE with LTE_LC_RRC_MODE_CONNECTED
    to adjust the time, when the message is really sent.
    So, which event/value should be processed?
    If "+CFUN=4" is sued, what need to be called/executed, to have the modem stack working for UDP again?
    Starting again from "lte_lc_connect_async(lte_handler);"?
    Something before? After?
  • Hello Achim,
    You should use LTE_LC_EVT_NW_REG_STATUS, as demonstrated in this LTE handler.
    Since you are using the LTE link controller library, you can use lte_lc_offline() instead of writing +CFUN=4 to the modem directly, but you might want to re-open the UDP socket again.
    If the modem looses its connection to the network, it will automatically retry to connect after a while, as long as there is an available network to connect to. So if flight mode is an appropriate choice or not depends a little bit on your use case.
    Markus
  • Though this case is rare in reality, I'm still not that sure. Anyway, that are my results so far:
    On reboot, I use
       lte_lc_init();
    and
       socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP)
    With that, the device is able to exchange UDP messages. In rare cases, sendto returns an error, and errno is ENETDOWN.
    In that case, I wait now, until the registered lte_handler (see above) reports, that the device is connected again. After that, I close the old socket and open a new one with
    again.
    So far, that works. Lets see, if it still works in 2-3 weeks :-).
  • Hello Achim,
    Thanks for your feedback :-)
    What is it you are not sure about?
    Markus
