unable to rebond after DFU
After preforming a DFU with the nrf connect app (ios) the device advertises and will "connect" with the nrf connect app, but its not actually connected which is evidence by going to my settings and trying to pair the device. In which case I get an unable to pair message. The only way I've found to fix this is by erase + flash the device.
Is there a configuration I have to set somewhere as to store bonding data (using NRF Connect/VS code)?
    Is this a "dummy" test, using the same application and NCS version on both sides, or do you upgrade anything during the DFU? How do you generate the DFU image? And can you send the partitions.yml file from both the original application and the application you are trying to update to?
    What chip are you using? Is this something I can reproduce with a DK? If so, is it possible to send the entire project folder(s)?
    Edvin
