Missing "coap_server_client_interface.h" when create openthread/coap_client project, CNS 1.9.0
I built the project on VS CODE, but it failed at the beginning
log output:
> Executing task: nRF Connect: Generate config nrf52840dk_nrf52840 for f:\nordic-sdk\project\coap_client <
Building coap_client
west build --build-dir f:\nordic-sdk\project\coap_client\dk-build f:\nordic-sdk\project\coap_client --pristine --board nrf52840dk_nrf52840 -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="f:/nordic-sdk/project/ot-cli;f:/nordic-sdk/project/coap_client"
Including boilerplate (Zephyr base): F:/nordic-sdk/ncs/v1.9.0/zephyr/cmake/app/boilerplate.cmake
-- Application: F:/nordic-sdk/project/coap_client
-- Zephyr version: 2.7.99 (F:/nordic-sdk/ncs/v1.9.0/zephyr), build: v2.7.99-ncs1
-- Found Python3: F:/nordic-sdk/ncs/v1.9.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Cache files will be written to: F:/nordic-sdk/ncs/v1.9.0/zephyr/.cache
-- Found dtc: F:/nordic-sdk/ncs/v1.9.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (f:/nordic-sdk/ncs/v1.9.0/toolchain/opt)
-- Found BOARD.dts: F:/nordic-sdk/ncs/v1.9.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: F:/nordic-sdk/project/coap_client/boards/nrf52840dk_nrf52840.overlay
-- Generated zephyr.dts: F:/nordic-sdk/project/coap_client/dk-build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: F:/nordic-sdk/project/coap_client/dk-build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: F:/nordic-sdk/project/coap_client/dk-build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: F:/nordic-sdk/project/coap_client/dk-build/zephyr/dts.cmake
Parsing F:/nordic-sdk/project/coap_client/Kconfig
Loaded configuration 'F:/nordic-sdk/ncs/v1.9.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration 'F:/nordic-sdk/project/coap_client/prj.conf'
Configuration saved to 'F:/nordic-sdk/project/coap_client/dk-build/zephyr/.config'
Kconfig header saved to 'F:/nordic-sdk/project/coap_client/dk-build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: F:/nordic-sdk/ncs/v1.9.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
-- OpenThread Source Directory: F:/nordic-sdk/ncs/v1.9.0/modules/lib/openthread
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Searching 16 bit integer - Using unsigned short
-- Check if the system is big endian - little endian
-- Package Name: OPENTHREAD
-- Setting default package version: thread-reference-20200818-ncs1-rc3-560-g02e61a2ed
-- Package Version: thread-reference-20200818-ncs1-rc3-560-g02e61a2ed
CMake Warning at F:\nordic-sdk\ncs\v1.9.0\zephyr\CMakeLists.txt:764 (message):
No SOURCES given to Zephyr library: subsys__net__pkt_filter
Excluding target from build.
CMake Warning at F:\nordic-sdk\ncs\v1.9.0\zephyr\CMakeLists.txt:1687 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: F:/nordic-sdk/project/coap_client/dk-build
[1/828] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/padlock.c.obj
[3/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/oid.c.obj
[4/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/cmac.c.obj
[5/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pk.c.obj
[6/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/asn1write.c.obj
[7/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/nist_kw.c.obj
[8/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pk_wrap.c.obj
[9/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/asn1parse.c.obj
[10/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/md.c.obj
[11/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ccm.c.obj
[12/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/base64.c.obj
[13/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/bignum.c.obj
[14/828] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[15/828] Generating include/generated/driver-validation.h
[16/828] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[17/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/aesni.c.obj
[18/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/platform_util.c.obj
[19/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/platform.c.obj
[20/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/version.c.obj
[21/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pkcs5.c.obj
[22/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pem.c.obj
[23/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pkcs12.c.obj
[24/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pkwrite.c.obj
[25/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pkparse.c.obj
[26/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/aria.c.obj
[27/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_commissioner.cpp.obj
[28/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_coap_secure.cpp.obj
[29/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_coap.cpp.obj
[30/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/backbone_tmf.cpp.obj
[31/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/bbr_leader.cpp.obj
[32/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_srp_client.cpp.obj
[33/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/bbr_local.cpp.obj
[34/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/trel_api.cpp.obj
[35/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_joiner.cpp.obj
[36/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/udp_api.cpp.obj
[37/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_dataset.cpp.obj
[38/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_network_data.cpp.obj
[39/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_srp_server.cpp.obj
[40/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_output.cpp.obj
[41/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_tcp.cpp.obj
[42/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_history.cpp.obj
[43/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli.cpp.obj
[44/828] Building CXX object modules/openthread/build/src/cli/CMakeFiles/openthread-cli-ftd.dir/cli_udp.cpp.obj
[45/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/border_router_api.cpp.obj
[46/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/backbone_router_api.cpp.obj
[47/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/backbone_router_ftd_api.cpp.obj
[48/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/channel_manager_api.cpp.obj
[49/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/coap_api.cpp.obj
[50/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/child_supervision_api.cpp.obj
[51/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/border_agent_api.cpp.obj
[52/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/channel_monitor_api.cpp.obj
[53/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/commissioner_api.cpp.obj
[54/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/coap_secure_api.cpp.obj
[55/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dataset_updater_api.cpp.obj
[56/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/diags_api.cpp.obj
[57/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_server_api.cpp.obj
[58/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/crypto_api.cpp.obj
[59/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dataset_api.cpp.obj
[60/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/history_tracker_api.cpp.obj
[61/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dataset_ftd_api.cpp.obj
[62/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/heap_api.cpp.obj
[63/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/error_api.cpp.obj
[64/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/dns_api.cpp.obj
[65/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/icmp6_api.cpp.obj
[66/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/instance_api.cpp.obj
[67/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/jam_detection_api.cpp.obj
[68/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/joiner_api.cpp.obj
[69/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/logging_api.cpp.obj
[70/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_raw_api.cpp.obj
[71/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ip6_api.cpp.obj
[72/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_metrics_api.cpp.obj
[73/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/netdata_publisher_api.cpp.obj
[74/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/network_time_api.cpp.obj
[75/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/multi_radio_api.cpp.obj
[76/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/link_api.cpp.obj
[77/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/message_api.cpp.obj
[78/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/netdata_api.cpp.obj
[79/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/random_noncrypto_api.cpp.obj
[80/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/random_crypto_api.cpp.obj
[81/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/netdiag_api.cpp.obj
[82/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/srp_client_api.cpp.obj
[83/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/sntp_api.cpp.obj
[84/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/tcp_api.cpp.obj
[85/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/ping_sender_api.cpp.obj
[86/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/srp_server_api.cpp.obj
[87/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/tasklet_api.cpp.obj
[88/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/server_api.cpp.obj
[89/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/srp_client_buffers_api.cpp.obj
[90/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/border_router/infra_if_platform.cpp.obj
[91/828] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[92/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/ndproxy_table.cpp.obj
[93/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/thread_ftd_api.cpp.obj
[94/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/api/thread_api.cpp.obj
[95/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/bbr_manager.cpp.obj
[96/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/backbone_router/multicast_listeners_table.cpp.obj
[97/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/crc16.cpp.obj
[98/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/coap/coap_secure.cpp.obj
[99/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/border_router/router_advertisement.cpp.obj
[100/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/border_router/routing_manager.cpp.obj
[101/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/appender.cpp.obj
[102/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/error.cpp.obj
[103/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/coap/coap_message.cpp.obj
[104/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/binary_search.cpp.obj
[105/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/coap/coap.cpp.obj
[106/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/heap.cpp.obj
[107/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/data.cpp.obj
[108/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/heap_data.cpp.obj
[109/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/heap_string.cpp.obj
[110/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/random_manager.cpp.obj
[111/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/logging.cpp.obj
[112/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/instance.cpp.obj
[113/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/string.cpp.obj
[114/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/notifier.cpp.obj
[115/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/uptime.cpp.obj
[116/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/tlvs.cpp.obj
[117/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/trickle_timer.cpp.obj
[118/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/time_ticker.cpp.obj
[119/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/settings.cpp.obj
[120/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/tasklet.cpp.obj
[121/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/message.cpp.obj
[122/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/common/timer.cpp.obj
[123/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/hkdf_sha256.cpp.obj
[124/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/ecdsa.cpp.obj
[125/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/aes_ecb.cpp.obj
[126/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/aes_ccm.cpp.obj
[127/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/sha256.cpp.obj
[128/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/hmac_sha256.cpp.obj
[129/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/mbedtls.cpp.obj
[130/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/diags/factory_diags.cpp.obj
[131/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/channel_mask.cpp.obj
[132/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/pbkdf2_cmac.cpp.obj
[133/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/crypto_platform.cpp.obj
[134/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/crypto/storage.cpp.obj
[135/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/link_raw.cpp.obj
[136/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/data_poll_handler.cpp.obj
[137/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/data_poll_sender.cpp.obj
[138/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_filter.cpp.obj
[139/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac.cpp.obj
[140/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_types.cpp.obj
[141/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/announce_begin_client.cpp.obj
[142/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_frame.cpp.obj
[143/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/border_agent.cpp.obj
[144/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/commissioner.cpp.obj
[145/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/sub_mac.cpp.obj
[146/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/sub_mac_callbacks.cpp.obj
[147/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/mac/mac_links.cpp.obj
[148/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_updater.cpp.obj
[149/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_manager_ftd.cpp.obj
[150/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset.cpp.obj
[151/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/joiner.cpp.obj
[152/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/energy_scan_client.cpp.obj
[153/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_local.cpp.obj
[154/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dataset_manager.cpp.obj
[155/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/dtls.cpp.obj
[156/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/panid_query_client.cpp.obj
[157/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/meshcop_tlvs.cpp.obj
[158/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/timestamp.cpp.obj
[159/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/joiner_router.cpp.obj
[160/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/meshcop.cpp.obj
[161/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dhcp6_server.cpp.obj
[162/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dhcp6_client.cpp.obj
[163/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/checksum.cpp.obj
[164/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dns_dso.cpp.obj
[165/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dns_client.cpp.obj
[166/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/meshcop/meshcop_leader.cpp.obj
[167/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dnssd_server.cpp.obj
[168/828] cmd.exe /C "cd /D F:\nordic-sdk\project\coap_client\dk-build\modules\openthread\build && F:\nordic-sdk\ncs\v1.9.0\toolchain\opt\bin\cmake.exe -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=2;BUILD_VERSION=v2.7.99-ncs1;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=0;__PROGRAM_START;NRF52840_XXAA;NRF_802154_ECB_PRIORITY=-1;NRF_802154_SWI_PRIORITY=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_CCA_CORR_LIMIT_DEFAULT=2;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45;NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=16;NRF_802154_PENDING_EXTENDED_ADDRESSES=16;NRF_802154_RX_BUFFERS=16;NRF_802154_CSMA_CA_ENABLED=1;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=0;NRF_802154_SECURITY_WRITER_ENABLED=0;NRF_802154_IE_WRITER_ENABLED=0;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;MBEDTLS_CONFIG_FILE="nrf-config.h";MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h"" -P F:/nordic-sdk/ncs/v1.9.0/modules/lib/openthread/etc/cmake/print.cmake"
PACKAGE_NAME=OPENTHREAD
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=2
__PROGRAM_START
NRF52840_XXAA
MBEDTLS_CONFIG_FILE=nrf-config.h
MBEDTLS_USER_CONFIG_FILE=nrf-config-user.h
[169/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip4_address.cpp.obj
[170/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/dns_types.cpp.obj
[171/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_address.cpp.obj
[172/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_headers.cpp.obj
[173/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/icmp6.cpp.obj
[174/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_mpl.cpp.obj
[175/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/socket.cpp.obj
[176/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/srp_client.cpp.obj
[177/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/nd_agent.cpp.obj
[178/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/sntp_client.cpp.obj
[179/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6_filter.cpp.obj
[180/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/srp_server.cpp.obj
[181/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/ip6.cpp.obj
[182/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/tcp6.cpp.obj
[183/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/netif.cpp.obj
[184/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/net/udp6.cpp.obj
[185/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/trel_link.cpp.obj
[186/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/trel_packet.cpp.obj
[187/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/trel_interface.cpp.obj
[188/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/anycast_locator.cpp.obj
[189/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/announce_begin_server.cpp.obj
[190/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/radio_platform.cpp.obj
[191/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/radio.cpp.obj
[192/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/radio/radio_callbacks.cpp.obj
[193/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/announce_sender.cpp.obj
[194/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/csl_tx_scheduler.cpp.obj
[195/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/dua_manager.cpp.obj
[196/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/discover_scanner.cpp.obj
[197/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/address_resolver.cpp.obj
[198/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/child_table.cpp.obj
[199/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/indirect_sender.cpp.obj
[200/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/link_metrics.cpp.obj
[201/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/energy_scan_server.cpp.obj
[202/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder_mtd.cpp.obj
[203/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/key_manager.cpp.obj
[204/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle_types.cpp.obj
[205/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/link_quality.cpp.obj
[206/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/lowpan.cpp.obj
[207/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mlr_manager.cpp.obj
[208/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder.cpp.obj
[209/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mesh_forwarder_ftd.cpp.obj
[210/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_leader.cpp.obj
[211/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle_router.cpp.obj
[212/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_local.cpp.obj
[213/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/mle.cpp.obj
[214/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_publisher.cpp.obj
[215/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data.cpp.obj
[216/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_tlvs.cpp.obj
[217/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_notifier.cpp.obj
[218/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/neighbor_table.cpp.obj
[219/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_leader_ftd.cpp.obj
[220/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_diagnostic.cpp.obj
[221/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_service.cpp.obj
[222/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/src_match_controller.cpp.obj
[223/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/radio_selector.cpp.obj
[224/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/time_sync_service.cpp.obj
[225/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/panid_query_server.cpp.obj
[226/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/network_data_types.cpp.obj
[227/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/uri_paths.cpp.obj
[228/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/thread_netif.cpp.obj
[229/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/router_table.cpp.obj
[230/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/child_supervision.cpp.obj
[231/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/channel_manager.cpp.obj
[232/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/channel_monitor.cpp.obj
[233/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/flash.cpp.obj
[234/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/topology.cpp.obj
[235/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/thread/tmf.cpp.obj
[236/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/slaac_address.cpp.obj
[237/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/otns.cpp.obj
[238/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/parse_cmdline.cpp.obj
[239/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/heap.cpp.obj
[240/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/jam_detector.cpp.obj
[241/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/history_tracker.cpp.obj
[242/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/hmac_sha256.cpp.obj
[243/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/srp_client_buffers.cpp.obj
[244/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/mbedtls.cpp.obj
[245/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/sha256.cpp.obj
[246/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/pbkdf2_cmac.cpp.obj
[247/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/storage.cpp.obj
[248/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/data_poll_handler.cpp.obj
[249/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-ftd.dir/utils/ping_sender.cpp.obj
[250/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/channel_mask.cpp.obj
[251/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/diags/factory_diags.cpp.obj
[252/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/ecdsa.cpp.obj
[253/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/aes_ccm.cpp.obj
[254/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/aes_ecb.cpp.obj
[255/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/crypto_platform.cpp.obj
[256/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/crypto/hkdf_sha256.cpp.obj
[257/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/data_poll_sender.cpp.obj
[258/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/border_agent_api.cpp.obj
[259/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/border_router_api.cpp.obj
[260/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/backbone_router_ftd_api.cpp.obj
[261/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/channel_manager_api.cpp.obj
[262/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/coap_api.cpp.obj
[263/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/backbone_router_api.cpp.obj
[264/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/commissioner_api.cpp.obj
[265/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/coap_secure_api.cpp.obj
[266/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/channel_monitor_api.cpp.obj
[267/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/child_supervision_api.cpp.obj
[268/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dataset_api.cpp.obj
[269/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dataset_ftd_api.cpp.obj
[270/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/error_api.cpp.obj
[271/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/crypto_api.cpp.obj
[272/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/heap_api.cpp.obj
[273/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/diags_api.cpp.obj
[274/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dns_server_api.cpp.obj
[275/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dns_api.cpp.obj
[276/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/dataset_updater_api.cpp.obj
[277/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/icmp6_api.cpp.obj
[278/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/instance_api.cpp.obj
[279/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/joiner_api.cpp.obj
[280/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/history_tracker_api.cpp.obj
[281/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/jam_detection_api.cpp.obj
[282/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/multi_radio_api.cpp.obj
[283/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/link_metrics_api.cpp.obj
[284/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/ip6_api.cpp.obj
[285/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/link_api.cpp.obj
[286/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/netdata_publisher_api.cpp.obj
[287/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/logging_api.cpp.obj
[288/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/ping_sender_api.cpp.obj
[289/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/message_api.cpp.obj
[290/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/network_time_api.cpp.obj
[291/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/link_raw_api.cpp.obj
[292/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/server_api.cpp.obj
[293/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/netdata_api.cpp.obj
[294/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/netdiag_api.cpp.obj
[295/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/random_crypto_api.cpp.obj
[296/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/srp_client_api.cpp.obj
[297/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/random_noncrypto_api.cpp.obj
[298/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/tasklet_api.cpp.obj
[299/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/sntp_api.cpp.obj
[300/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/udp_api.cpp.obj
[301/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/srp_server_api.cpp.obj
[302/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/tcp_api.cpp.obj
[303/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/thread_ftd_api.cpp.obj
[304/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/srp_client_buffers_api.cpp.obj
[305/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/trel_api.cpp.obj
[306/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/border_router/infra_if_platform.cpp.obj
[307/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/api/thread_api.cpp.obj
[308/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/backbone_tmf.cpp.obj
[309/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/bbr_local.cpp.obj
[310/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/multicast_listeners_table.cpp.obj
[311/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/bbr_manager.cpp.obj
[312/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/ndproxy_table.cpp.obj
[313/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/backbone_router/bbr_leader.cpp.obj
[314/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/coap/coap_secure.cpp.obj
[315/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/border_router/router_advertisement.cpp.obj
[316/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/border_router/routing_manager.cpp.obj
[317/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/appender.cpp.obj
[318/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/binary_search.cpp.obj
[319/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/data.cpp.obj
[320/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/coap/coap.cpp.obj
[321/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/coap/coap_message.cpp.obj
[322/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/crc16.cpp.obj
[323/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/heap_string.cpp.obj
[324/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/error.cpp.obj
[325/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/heap.cpp.obj
[326/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/heap_data.cpp.obj
[327/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/random_manager.cpp.obj
[328/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/instance.cpp.obj
[329/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/notifier.cpp.obj
[330/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/message.cpp.obj
[331/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/logging.cpp.obj
[332/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/string.cpp.obj
[333/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/tasklet.cpp.obj
[334/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/trickle_timer.cpp.obj
[335/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/uptime.cpp.obj
[336/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/settings.cpp.obj
[337/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/tlvs.cpp.obj
[338/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/timer.cpp.obj
[339/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/common/time_ticker.cpp.obj
[340/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/link_raw.cpp.obj
[341/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac_frame.cpp.obj
[342/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac_filter.cpp.obj
[343/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac_types.cpp.obj
[344/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac.cpp.obj
[345/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/sub_mac.cpp.obj
[346/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/announce_begin_client.cpp.obj
[347/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/border_agent.cpp.obj
[348/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/commissioner.cpp.obj
[349/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/mac_links.cpp.obj
[350/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/mac/sub_mac_callbacks.cpp.obj
[351/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_manager.cpp.obj
[352/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset.cpp.obj
[353/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/energy_scan_client.cpp.obj
[354/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/joiner.cpp.obj
[355/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_local.cpp.obj
[356/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dtls.cpp.obj
[357/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_updater.cpp.obj
[358/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/dataset_manager_ftd.cpp.obj
[359/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/meshcop_leader.cpp.obj
[360/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/meshcop_tlvs.cpp.obj
[361/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/panid_query_client.cpp.obj
[362/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/joiner_router.cpp.obj
[363/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dhcp6_client.cpp.obj
[364/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/meshcop.cpp.obj
[365/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/checksum.cpp.obj
[366/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/meshcop/timestamp.cpp.obj
[367/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dhcp6_server.cpp.obj
[368/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dns_dso.cpp.obj
[369/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dns_client.cpp.obj
[370/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dnssd_server.cpp.obj
[371/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/icmp6.cpp.obj
[372/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/dns_types.cpp.obj
[373/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_headers.cpp.obj
[374/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip4_address.cpp.obj
[375/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_filter.cpp.obj
[376/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/sntp_client.cpp.obj
[377/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_address.cpp.obj
[378/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6.cpp.obj
[379/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/nd_agent.cpp.obj
[380/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/srp_client.cpp.obj
[381/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/srp_server.cpp.obj
[382/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/socket.cpp.obj
[383/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/tcp6.cpp.obj
[384/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/ip6_mpl.cpp.obj
[385/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/netif.cpp.obj
[386/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/trel_interface.cpp.obj
[387/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/net/udp6.cpp.obj
[388/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/radio_callbacks.cpp.obj
[389/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/radio.cpp.obj
[390/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/radio_platform.cpp.obj
[391/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/trel_packet.cpp.obj
[392/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/announce_begin_server.cpp.obj
[393/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/address_resolver.cpp.obj
[394/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/child_table.cpp.obj
[395/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/csl_tx_scheduler.cpp.obj
[396/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/radio/trel_link.cpp.obj
[397/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/anycast_locator.cpp.obj
[398/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/indirect_sender.cpp.obj
[399/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/announce_sender.cpp.obj
[400/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/discover_scanner.cpp.obj
[401/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/dua_manager.cpp.obj
[402/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/link_metrics.cpp.obj
[403/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/key_manager.cpp.obj
[404/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mesh_forwarder_ftd.cpp.obj
[405/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mesh_forwarder_mtd.cpp.obj
[406/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/energy_scan_server.cpp.obj
[407/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/link_quality.cpp.obj
[408/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mle_router.cpp.obj
[409/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mle_types.cpp.obj
[410/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/lowpan.cpp.obj
[411/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_leader_ftd.cpp.obj
[412/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/neighbor_table.cpp.obj
[413/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mlr_manager.cpp.obj
[414/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mesh_forwarder.cpp.obj
[415/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_notifier.cpp.obj
[416/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_local.cpp.obj
[417/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_leader.cpp.obj
[418/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/mle.cpp.obj
[419/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_tlvs.cpp.obj
[420/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data.cpp.obj
[421/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_publisher.cpp.obj
[422/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_diagnostic.cpp.obj
[423/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/radio_selector.cpp.obj
[424/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_types.cpp.obj
[425/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/src_match_controller.cpp.obj
[426/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/router_table.cpp.obj
[427/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/panid_query_server.cpp.obj
[428/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/network_data_service.cpp.obj
[429/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/uri_paths.cpp.obj
[430/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/time_sync_service.cpp.obj
[431/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/topology.cpp.obj
[432/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/tmf.cpp.obj
[433/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/thread/thread_netif.cpp.obj
[434/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/channel_manager.cpp.obj
[435/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/heap.cpp.obj
[436/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/srp_client_buffers.cpp.obj
[437/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/history_tracker.cpp.obj
[438/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/parse_cmdline.cpp.obj
[439/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/otns.cpp.obj
[440/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/channel_monitor.cpp.obj
[441/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/flash.cpp.obj
[442/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/child_supervision.cpp.obj
[443/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/jam_detector.cpp.obj
[444/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_output.c.obj
[445/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/slaac_address.cpp.obj
[446/828] Building CXX object modules/openthread/build/src/core/CMakeFiles/openthread-mtd.dir/utils/ping_sender.cpp.obj
[447/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_sack.c.obj
[448/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_input.c.obj
[449/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/cc/cc_newreno.c.obj
[450/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/lib/bitmap.c.obj
[451/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_timewait.c.obj
[452/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/lib/lbuf.c.obj
[453/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/lib/cbuf.c.obj
[454/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_subr.c.obj
[455/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_usrreq.c.obj
[456/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_timer.c.obj
[457/828] Building C object modules/openthread/build/third_party/tcplp/CMakeFiles/tcplp.dir/bsdtcp/tcp_reass.c.obj
[458/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/camellia.c.obj
[459/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/cipher_wrap.c.obj
[460/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/cipher.c.obj
[461/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecp.c.obj
[462/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecdsa.c.obj
[463/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecp_curves.c.obj
[464/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/rsa.c.obj
[465/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/sha1.c.obj
[466/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecdh.c.obj
[467/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/des.c.obj
[468/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pk.c.obj
[469/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/md.c.obj
[470/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/hmac_drbg.c.obj
[471/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/pk_wrap.c.obj
[472/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/rsa_alt_helpers.c.obj
[473/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ripemd160.c.obj
[474/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/md5.c.obj
[475/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/sha256.c.obj
[476/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/sha512.c.obj
[477/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_aead.c.obj
[478/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_client.c.obj
[479/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_storage.c.obj
[480/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_mac.c.obj
[481/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_rsa.c.obj
[482/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_hash.c.obj
[483/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_ecp.c.obj
[484/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto.c.obj
[485/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_cipher.c.obj
[486/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/cipher_wrap.c.obj
[487/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/psa_crypto_slot_management.c.obj
[488/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
[489/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/cipher.c.obj
[490/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecdsa.c.obj
[491/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/chachapoly.c.obj
[492/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecp.c.obj
[493/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/dhm.c.obj
[494/828] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
[495/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecjpake.c.obj
[496/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/rsa.c.obj
[497/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/hkdf.c.obj
[498/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecdh.c.obj
[499/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/gcm.c.obj
[500/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
[501/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ecp_curves.c.obj
[502/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
[503/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/x509write_csr.c.obj
[504/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/rsa_alt_helpers.c.obj
[505/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ctr_drbg.c.obj
[506/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/x509_create.c.obj
[507/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/entropy.c.obj
[508/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
[509/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/x509_csr.c.obj
[510/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/x509_crl.c.obj
[511/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/debug.c.obj
[512/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/x509.c.obj
[513/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_cache.c.obj
[514/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/net_sockets.c.obj
[515/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_ciphersuites.c.obj
[516/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/x509_crt.c.obj
[517/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_cli.c.obj
[518/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_ticket.c.obj
[519/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_cookie.c.obj
[520/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_srv.c.obj
[521/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_tls13_keys.c.obj
[522/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_tls.c.obj
[523/828] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[524/828] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/F_/nordic-sdk/ncs/v1.9.0/mbedtls/library/ssl_msg.c.obj
[525/828] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedx509.a
[526/828] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedtls.a
[527/828] Linking CXX static library modules\openthread\build\third_party\tcplp\libtcplp.a
[528/828] Linking CXX static library modules\openthread\build\src\core\libopenthread-mtd.a
[529/828] Linking CXX static library modules\openthread\build\src\core\libopenthread-ftd.a
[530/828] Linking CXX static library modules\openthread\build\src\cli\libopenthread-cli-ftd.a
[531/828] Generating include/generated/offsets.h
[532/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[533/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[534/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[535/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[536/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[537/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[538/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[539/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[540/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[541/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[542/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[543/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
[544/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[545/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[546/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[547/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[548/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[549/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/util/fnmatch/fnmatch.c.obj
[550/828] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[551/828] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[552/828] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[553/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
[554/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cmds.c.obj
[555/828] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[556/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_rtt.c.obj
[557/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service.c.obj
[558/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
[559/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
[560/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
[561/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_cmds.c.obj
[562/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
[563/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
[564/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
[565/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_log_backend.c.obj
[566/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
[567/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_ctors.c.obj
[568/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
[569/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/device_service.c.obj
[570/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/devmem_service.c.obj
[571/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_virtual.c.obj
[572/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
[573/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init.c.obj
[574/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
[575/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/backends/shell_uart.c.obj
[576/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell.c.obj
[577/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_init_array.c.obj
[578/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_dtors.c.obj
[579/828] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_vtable.cpp.obj
[580/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
[581/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getnameinfo.c.obj
[582/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_misc.c.obj
[583/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[584/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/coap/coap_link_format.c.obj
[585/828] Building CXX object zephyr/CMakeFiles/zephyr.dir/subsys/cpp/cpp_new.cpp.obj
[586/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
[587/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[588/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
[589/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
[590/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
[591/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/coap/coap.c.obj
[592/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
[593/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[594/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
[595/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
[596/828] Building C object zephyr/CMakeFiles/zephyr.dir/F_/nordic-sdk/ncs/v1.9.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[597/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
[598/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
[599/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[600/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[601/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/constraint.c.obj
[602/828] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[603/828] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[604/828] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/residency.c.obj
[605/828] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
[606/828] Building C object zephyr/drivers/sensor/CMakeFiles/drivers__sensor.dir/sensor_shell.c.obj
[607/828] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[608/828] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[609/828] Building C object zephyr/CMakeFiles/zephyr.dir/F_/nordic-sdk/ncs/v1.9.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[610/828] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_shell.c.obj
[611/828] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[612/828] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[613/828] Building C object zephyr/drivers/ieee802154/CMakeFiles/drivers__ieee802154.dir/ieee802154_nrf5.c.obj
[614/828] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/F_/nordic-sdk/ncs/v1.9.0/nrf/drivers/entropy/entropy_cc310.c.obj
[615/828] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[616/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[617/828] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[618/828] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[619/828] Linking CXX static library zephyr\drivers\sensor\libdrivers__sensor.a
[620/828] Linking CXX static library modules\nrf\lib\dk_buttons_and_leds\lib..__nrf__lib__dk_buttons_and_leds.a
[621/828] Linking CXX static library zephyr\drivers\gpio\libdrivers__gpio.a
[622/828] Linking CXX static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[623/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[624/828] Linking CXX static library zephyr\drivers\console\libdrivers__console.a
[625/828] Linking CXX static library zephyr\drivers\flash\libdrivers__flash.a
[626/828] Linking CXX static library zephyr\drivers\serial\libdrivers__serial.a
[627/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[628/828] Linking CXX static library zephyr\drivers\ieee802154\libdrivers__ieee802154.a
[629/828] Linking CXX static library zephyr\drivers\entropy\libdrivers__entropy.a
[630/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[631/828] Building C object CMakeFiles/app.dir/src/coap_client_utils.c.obj
FAILED: CMakeFiles/app.dir/src/coap_client_utils.c.obj
F:\nordic-sdk\ncs\v1.9.0\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.7.99-ncs1 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF52840_XXAA -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_CSMA_CA_ENABLED=1 -DNRF_802154_ECB_PRIORITY=-1 -DNRF_802154_ENCRYPTION_ENABLED=0 -DNRF_802154_IE_WRITER_ENABLED=0 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_RX_BUFFERS=16 -DNRF_802154_SECURITY_WRITER_ENABLED=0 -DNRF_802154_SWI_PRIORITY=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_USE_RAW_API=1 -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I../../coap_server/interface -IF:/nordic-sdk/ncs/v1.9.0/nrf/drivers/mpsl/clock_control -IF:/nordic-sdk/ncs/v1.9.0/zephyr/include -Izephyr/include/generated -IF:/nordic-sdk/ncs/v1.9.0/zephyr/soc/arm/nordic_nrf/nrf52 -IF:/nordic-sdk/ncs/v1.9.0/zephyr/lib/libc/newlib/include -IF:/nordic-sdk/ncs/v1.9.0/zephyr/lib/util/fnmatch/. -IF:/nordic-sdk/ncs/v1.9.0/zephyr/soc/arm/nordic_nrf/common/. -IF:/nordic-sdk/ncs/v1.9.0/zephyr/subsys/net/lib/coap/. -IF:/nordic-sdk/ncs/v1.9.0/zephyr/subsys/net/lib/sockets/. -IF:/nordic-sdk/ncs/v1.9.0/zephyr/subsys/net/lib/openthread/platform/. -IF:/nordic-sdk/ncs/v1.9.0/zephyr/subsys/settings/include -IF:/nordic-sdk/ncs/v1.9.0/nrf/include -IF:/nordic-sdk/ncs/v1.9.0/nrf/lib/multithreading_lock/. -IF:/nordic-sdk/ncs/v1.9.0/nrf/subsys/net/lib/coap_utils/. -IF:/nordic-sdk/ncs/v1.9.0/zephyr/drivers/flash -IF:/nordic-sdk/ncs/v1.9.0/modules/hal/cmsis/CMSIS/Core/Include -IF:/nordic-sdk/ncs/v1.9.0/modules/hal/nordic/nrfx -IF:/nordic-sdk/ncs/v1.9.0/modules/hal/nordic/nrfx/drivers/include -IF:/nordic-sdk/ncs/v1.9.0/modules/hal/nordic/nrfx/mdk -IF:/nordic-sdk/ncs/v1.9.0/zephyr/modules/hal_nordic/nrfx/. -IF:/nordic-sdk/ncs/v1.9.0/modules/debug/segger/SEGGER -IF:/nordic-sdk/ncs/v1.9.0/modules/debug/segger/Config -IF:/nordic-sdk/ncs/v1.9.0/zephyr/modules/segger/. -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/mpsl/include -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/mpsl/include/protocol -Imodules/openthread/build/etc/cmake -IF:/nordic-sdk/ncs/v1.9.0/modules/lib/openthread/etc/cmake -IF:/nordic-sdk/ncs/v1.9.0/modules/lib/openthread/include -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_802154/driver/include -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_802154/sl/include -Imodules/nrfxlib/nrfxlib/nrf_security/src/include/generated -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_security/include -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_security/include/mbedtls -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_security/include/psa -If:/nordic-sdk/ncs/v1.9.0/mbedtls/include -If:/nordic-sdk/ncs/v1.9.0/mbedtls/include/mbedtls -If:/nordic-sdk/ncs/v1.9.0/mbedtls/include/psa -If:/nordic-sdk/ncs/v1.9.0/mbedtls/library -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_security/../crypto/nrf_oberon/include -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_security/../crypto/nrf_oberon/include/mbedtls -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/nrf_security/../crypto/nrf_oberon/include/psa -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -IF:/nordic-sdk/ncs/v1.9.0/nrfxlib/crypto/nrf_oberon/include -isystem F:/nordic-sdk/ncs/v1.9.0/zephyr/subsys/cpp/include -isystem F:/nordic-sdk/ncs/v1.9.0/modules/lib/openthread/zephyr/../include -isystem F:/nordic-sdk/ncs/v1.9.0/modules/lib/openthread/zephyr/../examples/platforms -isystem F:/nordic-sdk/ncs/v1.9.0/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros F:/nordic-sdk/project/coap_client/dk-build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -imacros F:/nordic-sdk/ncs/v1.9.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=F:/nordic-sdk/project/coap_client=CMAKE_SOURCE_DIR -fmacro-prefix-map=F:/nordic-sdk/ncs/v1.9.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=F:/nordic-sdk/ncs/v1.9.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/coap_client_utils.c.obj -MF CMakeFiles\app.dir\src\coap_client_utils.c.obj.d -o CMakeFiles/app.dir/src/coap_client_utils.c.obj -c ../src/coap_client_utils.c
f:\nordic-sdk\project\coap_client\src\coap_client_utils.c:8:10: fatal error: coap_server_client_interface.h: No such file or directory
8 | #include <coap_server_client_interface.h>
compilation terminated.
[632/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[633/828] Linking CXX static library zephyr\drivers\timer\libdrivers__timer.a
[634/828] Building C object CMakeFiles/app.dir/src/coap_client.c.obj
[635/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[636/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[637/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[638/828] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[639/828] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[640/828] Building C object modules/nrf/subsys/net/lib/coap_utils/CMakeFiles/..__nrf__subsys__net__lib__coap_utils.dir/coap_utils.c.obj
[641/828] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[642/828] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[643/828] Building C object modules/nrf/subsys/ieee802154/CMakeFiles/..__nrf__subsys__ieee802154.dir/nrf_802154_configurator.c.obj
[644/828] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
FATAL ERROR: command exited with status 1: 'f:\nordic-sdk\ncs\v1.9.0\toolchain\opt\bin\cmake.EXE' --build 'f:\nordic-sdk\project\coap_client\dk-build'
I tried to update the SDK, but the problem was not solved. What do I need to do next?
