Connection error in nrf52-ble-app-uart-c-multilink
I am using a code based on nrf52-ble-app-uart-c-multilink (https://github.com/NordicPlayground/nrf52-ble-app-uart-c-multilink)
If the central is working and the peripherals are incrementally connected, then it can connect to many devices (I have limited it to 16).
But if the peripherals stay connected (more than 4), and the central is powered on (or reset), then it will reset in every new attempt to connect with any peripheral.
i.e. endless resets.
The cause of the resey is in:
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
If I remove the APP_ERROR_CHECK, it doesn't reset, but it cannot connect to the reset of the peripherals.
The only way to fix it, is to shut down all the peripherals and start connecting again incrementally.
I recall that the advice was to increase the connection interval -
Can you explain how it affects? What should be the values if I want to connect up to 16 devices?
Thanks
Avi
