We need to enable internal RTC of SDK,
Pls share location of RTC driver implementation in nrf Connect SDK 1.8 & 1.9
can you please share example code for enabling RTC
Thank you,
Hitesh
Thank you,
Hitesh
Hi Hitesh,
You could refer to this unofficial GitHub page for a sample. In case you wish to learn or work more related to timing, you can also checkout the Zephyr kernel timer.
Priyanka
Can you pls share document / path of Zephyr related RTC api's to be referred
as we can observe in nCS\v1.8.0\zephyr\include\drivers\rtc we have header for maxim_ds3231.h & mcp7940.h
do we have any zephyr based api's as we can see for other peripherals in nCS\v1.8.0\zephyr\include\driver folder
Hitesh
Hi Hitesh,
You can refer to the following:
Also, all RTC peripherals in Zephyr are implemented with Counters with device specific APIs.
Priyanka
Hi Priyanka,
Thank you very much for quick response,
I have a question, as we can observe in this link of RTC & RTC interfaces is having an implementation towards Maxim ds3231 as same observed here in this path of zephyr driver - \nCS\v1.8.0\zephyr\include\drivers\rtc
currently we are having an dvk_653 board having nrf52833.
can you pls add more inputs or a direction so that we can have a development on the bl653, specifically we are looking for zephyr apis for RTC
Thank you,
Hitesh
Hi Hitesh,
Are you referring to a Real Time Clock? If this is the case, you will have to use an external one and find a corresponding driver.
But if you are referring to a Real Time Counter, then you should refer to the Counter API that I mentioned in the previous reply. Or if you just wish to use a timer, you can check the Timers.
Priyanka
