Start stop button ?
Dear Members,
How can I make a start/stop button with 1 button ?
Here's my handler :
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
				 case BSP_EVENT_KEY_0:
					 NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH ON\n");
            if (actual_state != BSP_INDICATE_FIRST)
                actual_state--;
						    //NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH ON\n"); //2Mar22 Rixtronix LAB
                actual_state = BSP_INDICATE_LAST;
						    NRF_LOG_INFO("BSP_EVENT_KEY 0 PUSH OFF\n"); //2Mar22 Rixtronix LAB
Any clues ?
Rixtronix LAB
  • Hi Karl,
    Thanks for the reply,
    So :
      case BSP_EVENT_KEY_1:
                         if(button1_state)
                                                    //OFF_function();
                                                SYSTEM_OFF
                                                    button1_state = STATE_OFF;
                                                    //ON_function();
                                                   SYSTEM_WAKEUP
                                                    button1_state = STATE_ON;
    What's the function for SYSTEM_OFF AND SYSTEM_WAKEUP for softdevice ?
    Rixtronix LAB
  • Hello again,
    I would recommend that you implement the entering of SYSTEM_OFF sleep in the same way that it is implemented in the BLE peripheral examples - such as the BLE NUS example - usually in the sleep_mode_enter function. This function first prepares the device for wakeup, and then places the device into SYSTEM_OFF sleep. You will not need to have the alternating function in the button handler then, because the only thing the device will be doing during SYSTEM_OFF sleep is to be ready for wakeup by the buttons configured for wakeup during the sleep_mode_enter function.
    Karl
  • Hi Karl,
    from ble_peripheral directory examples above,
    which example is using button with SYSTEM_OFF,
    and which example is using "button long push" for event ?
    Rixtronix
    I am not sure that anyone of them uses a button to initiate SYSTEM_OFF, not long button push (because they all are using the btn_ble_bsp variant), but you can easily assign a new event to button action using the bsp function I mentioned earlier, and then initiate SYSTEM_OFF in the same manner as demonstrated in the sleep_mode_enter function.
    Karl
  • Hi Karl,
    I have :
    /*************Rixtronix LAB 17 Mar 22*/
    err_code = bsp_event_to_button_action_assign(BSP_BUTTON_3,
        BSP_BUTTON_ACTION_LONG_PUSH,
        BSP_EVENT_KEY_3);
    and :
     case BSP_EVENT_KEY_3:
                //NRF_LOG_INFO("BSP_EVENT_KEY 3 PUSH OFF\n");
                         if(button3_state)
                                                    //ON_function();
                                                  NRF_LOG_INFO("BSP_EVENT_KEY 3 PUSH ON==> LONG PUSH >200ms\n");
                                                 //beep_v11();
                                                    button3_state = STATE_OFF;
                                                    //OFF_function();
                                                  //beep_v12();
                                                    button3_state = STATE_ON;
                if (actual_state != BSP_INDICATE_LAST)
                    actual_state++;
                    actual_state = BSP_INDICATE_FIRST;
    on bsp.h
    #define BSP_BUTTON_ACTION_LONG_PUSH (2)                  /**< Represents pushing and holding a button for @ref BSP_LONG_PUSH_TIMEOUT_MS milliseconds. See also @ref bsp_button_action_t. */
    but it's not responding to 2 seconds long push,
    What am I missing here ?
    Rixtronix
